Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    Skylake refresh OC results
    OK, this started as a high jack in the New 9800X thread.
    Please post up what you get regardless of the chip, any skylakeX refresh from 8-18 cores. Please post even if a spud. Not much out there on what these chips will do other than reviewers that all pretty much shared a few ships and all 9980XE. User Benchmark is starting to get a few up there but still sparse. I have the top scoring 9940X there. Whats sad is I got my best ever Firestrike Ultra, Timespy extreme and realbench scores. On 3D marks go to compare with similar CPUs.......Im all alone. two runs up, one at 4.7GHz and another at 4.8GHz
    Ill update this post with any changes if I manage to squeeze out another 100MHz or 2. Im optimistic that I can get to 4.9 with more tweaking, dropping a couple of cores back 100MHz (the hot ones) etc. Rad fans on controller didnt even hit 100%! Please do the same just adding an edit to your post leaving all original content.
    My sample
    9940X @ 4.8 GHz
    XMP on
    AVX 3
    512AVX 5
    sync all cores
    multi at 48
    adaptive to 1.225
    svid disabled
    LLC at 4
    power limits long and short to max 4095
    CPU current at 140%
    ASUS multiccore enhance disabled
    Peak hottest core 85C
    If I didn't list it its at default
    All other settings to run my current hardware listed in my specs.
    https://valid.x86.fr/3a2fcj
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme Encore
    Processor10980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2721DE
    Storage #1Intel Optane 905P PCIe
    Storage #2Samsung 980 Pro
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    111
    1,648
    Hello
    You would have a screen of CoreTemp or other (to see the temperature of all the cores) ?
    What frequency / voltage for the cache ?
    Thanks
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme Encore
    CPU: i9 10980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 905P PCIe
    DATA: Samsung 980 Pro
    SOUND: Asus Xonar Phoebus
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3501 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 NEO 49 Firmware 1005.1
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 11 Insider Preview 22463.1000
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    88
    726
    The most interesting model of Skylake X Refresh for me was 9800X and 9900X which L3 cache increased from 1.375MB per core to 2.0MB per core.
    If you could measurements clock for clock performance gap from 7800X VS 9800X or 7900X VS 9900X at the same setting on same clock speed
    on many kind of benchmarks , It may more interesting point.*
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,854
    Quote Originally Posted by tistou77 View Post
    Hello
    Thanks
    cache is at default auto. Havent tweaked that yet.
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,854
    Quote Originally Posted by restsugavan View Post
    Feel free to pick up a 9980XE to bench against your current SKU and post it up.
    If folks who get the 99XX post up their results you can draw you own conclusions, however no silicon is the same. My 7900X hit 5GHz and another member had trouble getting a 9900X past 4.5GHz, took him 4 different chips to get to 4.7GHz.
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    88
    726
    Quote Originally Posted by JustinThyme View Post
    Nice info , However 9980XE and my 7980XE both also have 1.375MB L3 Cache per core. So for 9980XE performance I didn’t interesting.
  7. #7
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,854
    Im interested in what a year of process improvements has brought to the table as well as soldered IHS with no delid. Either way grab a cold one and sit back and relax to see if anyone posts up the results of what you are interested in. I wasnt going to upgrade from a 5GHz 7900X to a crap shoot with more cache. I was torn between the 9940X and 9960X wanted more cores but not a low clock speed. FYI for all, NewEgg just sent me notification that the 9960X is in stock.
  8. #8
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    202
    I've tested my 9900X a little bit more and here goes:
    Prime95 AVX disabled:
    4.3 1.125 V
    4.4 1.15 V
    4.5 1.2 V
    Cinebench:
    4.6 1.21 V
    4.7 1.3 V
    4.8: Cannot do a single run with any voltage.
    In the end it's a little better than I initially thought but still way worse than my delidded 7900X. 4.6 could be doable with better cooling but this is in my secondary PC with a very simple loop and a tight packed case. Gonna run it "stock" per core usage setting with OCd cache and RAM.
    Main: Xeon W-3175X - Dominus Extreme - 48 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-7980XE - H150i Pro - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
  9. #9
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,854
    Im a bit perplexed with the 9900X chips. Another Member had 3 that wouldn't do 4.6 then got 4th to 4.7 with higher Vcore than it should take. My delidded 7900X did better with less juice, 1.250.
    I spent the better part of the afternoon trying to get my 9940X to 4.9 and its just not happening. Got it to post at 1.285 but the first sign of a decent load from anything and I was seeing blue. I may mess a little more one day when I get bored but Im thrilled to get it to 4.8 stable as a rock. After I got done playing trying 4.9 I started dialing back the Vcore to see where I could get. Down to 1.195 ATM and still stable with a drop in temps from 85C max to 79C max.
    Ill start dabbling with mesh next then RAM last even though it runs XMP just fine and I rolled it back from 3800 C19 to 3600 C15 earlier just for giggles. It boots great and I ran several benches then out of nowhere time stood still. Complete freeze. Got RB up 3K as well, enough to get the 7 spot if I could upload.
Name:	realbench 010618.png
  10. #10
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Abaidor's Avatar
    Dec 2017
    12
    264
    I will be more than happy if I manage to get my 7940X to 4.8Ghz all cores. Great job there Justin!
    Now if only I could ever receive the direct die frame - what is happening is ridiculous at best with Caseking. They were supposed to have this in Stock on the 12th of December when I ordered in November and almost one and a half month later still no firm ETA! At this point I would be better off if I had ordered the frame from Iceman (alliexpress) even though it had 25 days shipping time. I really don't know what the hell is going on and why can't they call their supplier and ask him in plain English: WHEN DO YOU EXPECT TO MAKE THE DAMN FRAMES! I would have made it myself in a local machine shop if I had the plans all this time damn it!
    Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
