Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Guru: Green Belt Array FlanK3r PC Specs
    FlanK3r PC Specs
    MotherboardROG Crosshair VII Hero WiFi
    ProcessorAMD Ryzen 7 3800X
    Memory (part number)G.Skill TridentZ Neo RGB 2x16GB 3600MHz
    Graphics Card #1Asus Dual RTX 2060 O6G
    Graphics Card #2Asus Radeon R3 230
    Graphics Card #3Saphire R9 270X Toxic
    Graphics Card #4ROG GTX980TI Poseidon
    MonitorAOC 27"
    Storage #1Samsung 850 PRO 512 GB
    Storage #2HyperX 3K 240GB
    CPU CoolerROG Ryujin 240
    CaseLian-Li Dynamic O11 XL + NZXT Noctis
    Power SupplyCM V850 + Corsair TX750
    Keyboard Microsoft Sidewinder
    Mouse Razer Deathadder Elite
    Headset HyperX Cloud + ROG Strix Go 2.4
    Mouse Pad Roccat Tatto
    Headset/Speakers ROG Magnus
    OS Windows 10 + Windows 7
    Network RouterAsus DSL-AC88U
    FlanK3r's Avatar
    Sep 2010
    110
    604
    ROG Ryujin 360 - basic review on TR4
    History of CPU cooling is longride way. From basic coolers to extreme cooling as example LN2. We can remember 20 years ago...Yes, everything looks like stock boxed cooler But different was the cooler for AMD Thunderbird CPUs.
    Cooling systems were evolved, first home liquid cooling and worldwides forums were full of users. They shared about all inforamtion how to do home setups, how tweak the processors etc. etc. It is history. Today people want to have cooling system ready to use with good design, easy installation and silent working.
    At the end of 90s started also extreme overclocking. In Japan guys cooled PC with dry ice or liquid nitrogen.
    About 10 years ago there was big market with aircooler with high cooling performance and low noise. In this age came first AIO Coolers. Im thinking, one of the first was Corsair H50 and Antec Kuhler series. This Antec (model 920) was very strong, but with max RPM really noisy. Later tthis cooler was as revision for AMD Bulldozer bundle (CPU+FX AIO cooler).
    Do you know, Asus had Air coolers many years ago? Do you know Asus Triton or Asus Silent Knight? So this company has some experience with cooling and in 2018 they are selling AIO coolers. There is ROG Ryuo and higher model ROG Ryujin. Ryuo exists in 120 a 240 mm version of radiators. Ryujin has 240 and 360 models. But we will focused on highest ROG Ryujin 360 today.
    1. Desription and Ryujin theory
    Noctua fans, cool design, sleeved tubes, adressable RGB LED and OLED display and inside the embedded fan. Thats it!
    Mentioned before - Noctua Industrial fans
    This is what I like. Emedded small fan to cools VRM of the motherboard or first M2 slot. This is special y necessarily for Z390 with 9900K OC combination or X299 or X399 CPUs.
    OLED display and some functions on it. U know propably Linus face on display at Computex time
    And AURA Sync support via LiveDash app
    2. packaging
    On the box, in ROG style, front part shows important information about Noctua coolers and on the back side of box are features like OLED display 1.77", small "VRM" fan on CPU block and about AURA Sync.
    Inside the box are three Noctua Industrial fans about size 120x120x25mm. Those fans working in range 450-2000 rpm and cooling performance is up to 122CFM. You propably know, Noctua fans are really effective in performance/quiet ratio. Specs says only 29.7 dB!!
    Fans have braided cable with 4-pin PWM connector. On the photo you can see noise reduction rubber pads.
    Socket reductions and many screws for installation. The cooler is from factory ready for LGA115X motherboards. But you cand find in accessories AM4 bracket and universaly backplate. For TR4 you need change the bracket which is inside the box of TR4 CPU (Threadrippers).
    Plastic design cover over the CPU pump. You can see plastic "window" on the bottom corner for OLED display informations or animations.
    Radiator is classic 360 alluminium material, thats mean for 3x 120mm fans in one row. Real lenght of radiator is over 390mm, widht 121mm and thickness is 27mm.
    Rubber tubes have about 430mm lenght including screws (390mm without it). This is more than enough for most of cases.
    CPU integrated block contact is a copper. The side view on the block show the small fan inside for VRM cooling. The size of fan there is 60mm. On the top of integrated block is OLED display.
    Connectors in my hands including 2x PWM female connectors, SATA cable for power, USB 2.0 connector and 4-pin PWM for the pump.
    Who knows me, knows me ....AMD 3000+, AMD x2 4600+ EE, AMD X4 955 BE C2,2x AMD X4 965 BE C3, AMD X4 970 BE C3, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD x6 1100T BE, 2x AMD FX-8120, 2x AMD FX-8150, FX-6300, FX-8300, FX-8320E, FX-8320, FX-8350, FX-8370, FX-8370E, FX-9370, FX-9590, AMD A8-3850, AMD A8-3870K, A8-5600K, A10-5800K, A10-6800K, A10-7850K, A10-7870K, A 5150, Athlon x4 860K, Intel i7-5960X, i7-6700K, Intel i7-4770K, Intel i7-980x, Intel i7 2600k, Intel i7-3770K, i7-3930K.
    FlanK3r PC Specs
    MonitorAOC 27"
    FlanK3r's Avatar
    Sep 2010
    110
    604
    3. AIO installation process
    Zhe installation process is easy. From stock is preinstalled cooler for Intel LGA type of platform. For AMD AM4 we have reduction in the package. For TR4 socket we can use Asetek reduction from CPU package. Then we will use screws for hold the cooler.
    First remove the reduction, use light push and rotate to remove the stock reduction. After you can add new one from CPU package (TR4)
    Now you screws up directly to the motherboard - no backplate needed for TR4 socket.
    In the finish looks like that...
    In the end I set up the Noctua fans on radiator.
    4.SOFTWARE and AURA
    After start the PC has ROG Ryujin own small storage for firmware (on the screen). Do not remove this storage or do not format it.
    Fan Xpert is part of Ai Suite software (Asus motherboards). I recommend download last version from website of MB product. And is it good way to tweak your cooling depends on temps and rpms.
    LiveDash app is for tweaking your OLED display and set RGB colors or synchronization AURA effects. You have choice between hardware monitoring informations or custom gif animations or custom banner or simply some yours photos. Few examples lower.
    Bud Spencer gif :-)
    https://youtu.be/UXPK_XcoIXU
    5. TEST SYSTEM
    AMD Ryzen Threadripper 1950X (stock i OC nastavení)
    ROG zenith Extreme
    ROG Ryujin 360
    ROG Strix GTX 1050 O4G
    4x 8GB HyperX Predator@3200 MHz
    Corsair AX1200
    Windows 10 Home 64bit
    software for testing:
    CinebenchR15, AIDA 64 stress test, hwinfo, Sound meter - phone app.
    noise level I tested on open case (read the benchtable) from 20-30cm distance. In table are examples of noise (in Czech language, 10db=scour the leaves on tree, 20dB=calm in nature, 30dB = very quiet room, 40dB = normal noise background, 50 dB =normal conversation )
    6. TEST RESULTS ON CPU STOCK SETTINGS
    Idle
    The cooler is in CPU idle in Windows very quiet, only about 37 dB, sometimes are Noctua fans spinning off and the highest noise source was PSU and chokes inside...
    Load on CPU stock settings
    First time I run CinebenchR15, max temps on CPU were 60 C.
    After I ran AIDA stress test (including AVX) After the temps was the same, I measured noise also. It was about 46dB average, keep in mind, it is still open case and very close distance (20-30cm) - thats not typical customer situation. And must say, 46 dB is still solid quiet on this distance. The max temps were up to 70 C. For so big boy as Threadripper is it good result.
    Max fans+pump speed
    Noctuas fans are still very solid quiet, but pump is a little noisy. You can see result is now about 56 dB
    FlanK3r PC Specs
    MonitorAOC 27"
    FlanK3r's Avatar
    Sep 2010
    110
    604
    7.CPU OVERCLOCKED - RESULTS
    Ussually first gen of Threadrippers can hold between 3.9 GHz up to 4.1 GHz, depends on quality of chip and cooling methods. My sample is solid, I tested it one year before.
    With LLC3 and 1.275Vcore I got final frequency on chip 3950 MHz. I was close to 3975 MHz, but after some time I got error. Average temperature was 71 C on chip.
    I left fans on the maximum for to be save for highest CPU stable frequency...So again 56 dB
    I tried also Cinebench on maximum. Up to 4050 MHz on all 16 cores and 32 threads.
    If I compared full cover IHS AIO cooler with ROG Ryujin 360, there is some difference. Still, TR4 coolers are more specialized and some part of heat can be on corners of IHS (there are not CCX, but some heat from it). So basically temps on die are a little lower and thats mean a little higher OC. But AIO TR4 are only for TR4 platform and can not use it for another else. ROG ryujin is more multipurpose.
    8.CONCLUSION
    The price is not the best, but...I like design of the cooler, OLED display and also small cooler to cooling the VRM. Thats very good idea. Of course I can not forget on Noctua Industrial series fans. These are really quiet. Manufactory process is on high level - classic Asus. I like also software part to tweak the pump+fans in FanXpert. The main HW statistic information you can have on your OLED display. Why not. The cooler is really quiet , specially in idle. Of course with high overlcocking the noise will be a bit higher, specially on platfrom, where the CPU has close to 300W package :-) But on "standard" CPUs it will be different story (ussually around 180-200W after OC).
    I see disadvantage in you con not refill the liquid or adding next hardware to the liquid cooling circuit as example GPU. Alphacool Eisbaer has this feature. But it is first ROG AIO cooler, so maybe in next version in future? Anyway I can recommend you this cooler if you are ROG fan or if you want quiet and good performance AIO cooler with active VRM cooling and wow effect OLED display
    FlanK3r PC Specs
    MonitorAOC 27"
    FlanK3r's Avatar
    Sep 2010
    110
    604
    next step: Z390+i9-9900K
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    27
    1,781
    Quote Originally Posted by FlanK3r View Post
    8.CONCLUSION
    Hi. I need you help
    I got a firend computer to build. THe x399-3 witht 2950x and the aio
    After few hours I manaje to add the bios. (dont ask) i mount the last bios 0808. Install windows install the chipset 18.40.02 the last one.
    I can not install the ai suite in order to control the AIO. You can PM. with the help
    I the mean time i will try to add the update of the AIO and isntall somehting. since i need to delover my firends cumputer for today 5pm PT
    Thanks for any help. i am good with x299 and z390 and below but these is new for me.
    Learn, Play Enjoy!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,756
    I'm reading a little late, but very thorough review!
    I think reduction should be retention. That part confused me a bit.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  7. #7
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    27
    1,781
    I estilo need help. I am running x399-e. With 2950x. Bios 0808. Last chipset from.asus website. I can not run the ai suit. I all ready running the firmware update. But what ai suite and what app or dash?? Right know I unplug the current, and usb from.the aio in order restart the device.
    What find 1. It will not save the settings then issues is aisuite
    Help is a friend work computer and still need to work why the aura is not detecting the 2080ti occasions edition and low scores in open gl in cinebench
    Learn, Play Enjoy!
  8. #8
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,756
    I don't know, Itzycharles
  9. #9
    FlanK3r PC Specs
    MonitorAOC 27"
    FlanK3r's Avatar
    Sep 2010
    110
    604
    itzycharles: whats your model of motherboard? If Asus, you are OK. If not, you can not install the Ai Suite.
    IF YES: download last version of AI Suite, eg from model Maximus XI. Version from maximus XI working OK on X399 Asus boards
  10. #10
    MrAgapiGC PC Specs
    Processor9900K
    CaseNzxt H700
    Mouse Asus Spartha
    MrAgapiGC's Avatar
    Nov 2011
    27
    1,781
    Thanks for the msg. I have to send the pc to my friend office all ready. i have not have the chance to check errors. What i did add a spliter and conect the fans to cpu and the pump on the aio port of the x399-e. control the pump on bios. and that make the trick.
    I will try to get one to my z390 code xi as soon i can. I have to ditch the ai suite on my board cause It was make some issues with Davinci video software.
    I will ask help to developers since I am running the drivers from the post (drivers only) and is very stable now. there few builds that i need to help users here that they do not speak English.
    Learn, Play Enjoy!
Tags for this Thread
