Results 1 to 9 of 9
    ROG Member Array
    Dec 2018
    7
    MAXIMUS XI came without M2 heatsinks
    As per title, did anybody else experienced this? My retailer assured me the board was brand new and i already contacted Asus Customer Support in regards of this.
    Im wondering what could happen there. The worst is that i only noticed it should have those heatsinks after a month and my retailer cant do anything about it
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,759
    Here is the accessories list for XI HERO (WiFi). What makes you think you are missing something? Does the box list contents that are missing?
    Accessories
    User's manual
    4 x SATA 6Gb/s cable(s)
    1 x M.2 Screw Package
    1 x Supporting DVD
    1 x ASUS 2T2R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
    1 x SLI HB BRIDGE(2-WAY-M)
    1 x ROG big sticker
    1 x Q-Connector
    1 x Extension Cable for RGB strips (80 cm)
    1 x Extension cable for Addressable LED
    1 x ROG coaster(s)
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Dec 2018
    7
    Quote Originally Posted by xeromist View Post
    Accessories
    User's manual
    1 x Supporting DVD
    1 x ROG big sticker
    1 x Q-Connector
    1 x ROG coaster(s)
    My board have M2 heatsinks missing, they are physically not present on the board. All pictures found online and on the box shows them, that board is advertised to have them, all unboxing videos shows those heatsinks.
    I wouldnt even know if i didnt watch unboxing video
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,759
    Ah, so you're talking about the slot covers that match the rest of the heat sinks? Unfortunately I doubt those could be acquired separately after the fact. The good news is that M.2 drives don't need them to function (and work better uncovered anyway) but I understand you wanting to have everything.
    It sounds like the retailer is mistaken. Those covers are attached to the board from the factory so the only way they could be missing is if someone removed them (possibly when installing drives) and then repackaged the board. Perhaps the retailer accepted it as a return and didn't realize something was missing. But if they have a 30 day return window and you passed it I don't think there's anything you can do. The ASUS warranty covers defects but since these are just decorative covers you wouldn't be able to do anything with an RMA.
    ROG Member Array
    Dec 2018
    7
    Thank You for your reply.
    I did ask the retailer and he assured me it wasnt a return which i doubt myself, and their return window of 72 hours is just ridiculous. If they are decorative i dont really need them i only wanted to know if thats common, thanks again!
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    Not common at all. Its expected that things will be missing with open box buys but not new in original packaging.
  7. #7
    ROG Member Array
    Dec 2018
    7
    Quote Originally Posted by JustinThyme View Post
    Thanks for confirmation. I guess i will have to change my supplier. It bothers me that after 10 years they cant help me with this. I mean i spent couple grand with them over those years
  8. #8
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,759
    Quote Originally Posted by 86kotek View Post
    Well, in my experience most retailers aren't going to do anything after a month. But if they require you to report issues within 72 hours I agree that you can probably find better.
    Regarding cooling the drives, I run mine naked and they work fine. Technically GamersNexus discovered the controllers are better cooled and the nand cells are better hot, so take that for what you will.
  9. #9
    ROG Member Array
    Dec 2018
    7
    Thats good to know thanks
Tags for this Thread
