Results 1 to 9 of 9
    ROG Enthusiast Array
    Mar 2015
    34
    All SUITE - disables beQuite AIO Pump?
    Another problem with my ROG Crosshair VII here...
    I have Ryzen 2700x + beQuiet silentLoop 280mm.
    Pump is connected to AIO header, and both radiator coolers connected to CPU fan headers (CPU + CPU OPT).
    On linux all works fine, in bios all works fine - in windows (WITHOUT All Suite everything seems fine).
    If i install All suite and start FAN calibrating process - IT just disables AIO pump... (literally - while starting calibration, watched with hwinfo64 - it goes down to 0 - after 3-5 secs system shut's down... need to unplug power cord to get it up running).
    P.S.
    In bios, Q-Fan is disabled for AIO pump (so no software control, always max for this header).
    If after format i don't install All suite, everything works fine also, problems start AFTER i install All suite...
    Any ideas?
    Thanks.
    Aug 2018
    70
    ai suite is still so much buggy, i suggest you to change your setup:
    go plug AIO pump to CPU FAN headers
    and 2 radiator fans to chassis fan headers (you might need a fan splitter here if you want to setup more chassis fans)
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    999
    When running Fan Expert calibration, are you being patient enough to let the pump spin back up? All the fans/headers are spun to a stop and them spun back up. This way the software knows minimum voltages for each fan/pump on each header.
    You can also disconnect the pump from the AIO headers and calibrate then re-connect the pump. This will give the AIO header a default fan curve.
    ROG Member Array
    Dec 2018
    8
    This is what my corsair H-115i 280mm radiator / cooler runs like on my i9-9900k while doing nothing but watching netflix and this forum (2 monitors)
    I have used AI suite as well and have used the fan expert
    to me this seems fine, but I might be wrong.
    Your's shut down your pump? o_O
    My Asus ROG STRIX Z390-F has a header for "AIO PUMP" which I used to power the pump- the AIO has a seperate SATA Power connector, which is used to power the the Radiator Fans I guess + also some USB connection to control it / the RGB maybe.
    How is yours looking?
    Mar 2015
    34
    Quote Originally Posted by mdzcpa View Post
    I can be patient enough, but is i wrote in beginning - PC shut's down in process (because of AIO pump being disabled - overheat protection i think). =)
    Also - in bios all controls for AiO pump are disabled (so always running 12v / @100%), i think issue is - that fanXpert tuning does fetch this config from bios and try's to tweak AIO pump anyway (disabling it in process for calibration).
    Mar 2015
    34
    Quote Originally Posted by chris69 View Post
    Seems legit, 1000+rpm for pump, and flowing rpm on fans.
    Yes, ASUS fan calibration software disables pump in process (despite config in bios - which is set to always run @12v/100%) to calibrate it, and i think in this moment overheat protection disables PC (runs quickly to 90C+).
    As i wrote in topic start, my looks like this: pump connected to AIO pump header (+ set in bios be always 12v/100%), and both radiator fans connected to CPU headers.
  7. #7
    Mar 2015
    34
    Now, this is hillarious...
    Gave it last try, now when opening Fan Xpert 4 - it's insta shutting down: https://youtu.be/h27CqOhSZzA
    Seems it's better not to install this software at all )
  8. #8
    Mar 2015
    34
    Problem solved (if someone else have this problem (before AISuite tuning set all CPU OC stuff in bios (Extreme Tweaker) to default (otherwise on core boost - your max temp can go to 197C(???) - that triggers instant shutdown of PC).
    after tuning you can return to your D.O.C or other settings. (this still needs investigation from ASUS, cus 197C issue is alive).
  9. #9
    ROG Enthusiast Array Rufinoman PC Specs
    Rufinoman PC Specs
    Laptop (Model)Lenovo
    MotherboardAsus ROG Crosshair Hero VII WiFi
    ProcessorAMD Ryzen 2600X
    Memory (part number)32Gb CMK16GX4M2A2400C16
    Graphics Card #1Asus ROG Strix RX5700XT OC 8Gb
    MonitorSamsung C27F591
    Storage #1WDS500G2B0B
    Storage #2Samsung SSD 850 Evo 250Gb
    CPU CoolerCorsair H100i RGB Platinum
    CaseCoolermaster Storm Trooper
    Power SupplyCorsair RM850x, Full Modular
    Keyboard Corsair Strafe RGB Silent
    Mouse Corsair M65 Pro
    Headset Corsair HS40
    Mouse Pad Razer
    Headset/Speakers Corsair HS40
    OS Windows 10 Pro x64
    Dec 2017
    32
    CH VII here.
    All my OC stuff is set to default anyway and it still shuts down. I don't OC anyway.
