01-05-2019 05:59 PM - last edited 3 weeks ago by ROGBot
01-06-2019 12:22 AM
wollpie wrote:
Hello all.
Apparently I'm lucky and my Strix Hero II doesn't have any FPS issues or anything like that. The laptop never reaches above 85 C from what I've seen. However, I have on issue with it. Whenever I turn on the laptop or at random points when it should be idling, the GPU fan hits up 4900-6400 RPM. Obviously this would not be an issue if I was playing something but all I'm doing it looking at my desktop. I bought this laptop because I believed it would be good for both using in class and gaming, but if I'm going to have a jet engine go off every time I open my laptop, it's going to be an issue. Another thing worth noting is that the CPU idles around 2.9 GHz sometimes. I have no explanation for this either.
I've gone no further than looking around online if anyone else has this kind of issue and I've not really found any solutions. I can provide pictures/benchmarks if needed.
Thanks.
01-06-2019 02:27 AM
Beamazing wrote:
Hi try to record video of issue please.I think it is normal when u open up a lid and press power button some laptops have fan spinn off opposite directions,but i am not sure if it should do that while is on desktop , or surfing.How long it goes HIGH RPM two sec , one minute long ?
What i can advise u , maybe u can control fan speed in ROG gaming Center , otherwise but i am not 100% sure in this one it is called SpeedFan.I can control fan RPM on my alienware 13 r3 in HWinfo64 also but i dont have that option on GL702vmk...
01-06-2019 04:57 PM
Vsparda wrote:
there is a virus dude try downloading malwarebytes and scan it becuase i have the same issue once and the cause is virus
01-06-2019 05:18 PM
01-07-2019 02:04 AM
wollpie wrote:
A video wouldn't show much. Basically, I open the laptop, turn it on, and after it gets to the Windows sign in screen, the GPU fan starts. It's not a temporary thing either. I once turned it on and took it away for around 1-1.5 hours and it was on for most of the time. It only tuned off for like 5 minutes before going back to around 6k RPM. I've set the fans to silent in the ROG Gaming center but it doesn't help. I have looked into Speedfan as you suggested but it does not allow me to control GPU fan speed.
01-07-2019 01:21 PM
Vsparda wrote:
have you tried pressinng FN+F5?? if not why not updating your bios
01-07-2019 02:04 AM
01-07-2019 01:23 PM
desuzarasu wrote:
did you check on your processes? also, if the laptop is new, maybe windows is trying to resume downloading updates (check your network too)
01-08-2019 09:58 AM
