Page 1 of 36 1 2 3 11 ... LastLast
Results 1 to 10 of 355
    ROG Enthusiast Array csbin PC Specs
    csbin PC Specs
    MotherboardAsus ROG Rampage VI APEX
    ProcessorIntel Core i9-7980XE
    Memory (part number)G Skill F4-2400C14Q-16GRK
    Graphics Card #1AMD Radeon R9 290X
    Sound CardASUS ROG Xonar Phoebus
    MonitorDell U2515H
    Storage #1Intel DC S3500 120G
    Storage #2HGST HUS724020ALA640
    CPU CoolerCoolerMaster Nepton 120XL
    CaseCoolerMaster HAF XM
    Power SupplyAntec HCP-1300 PLATINUM
    OS Microsoft Windows 10 Professional
    Aug 2013
    60
    Cool Rog rampage vi extreme omega
    ROG Guru: Orange Belt Array Abaidor PC Specs
    Abaidor PC Specs
    MotherboardRampage VI Extreme
    Processori9-7940X
    Memory (part number)F4-3600C17Q-64GTZR | Trident Z RGB 64GB
    Graphics Card #1Asus Strix 1080Ti OC
    Storage #1Samsung 960 Pro 512GB
    Storage #2WD 10TB Gold
    CPU CoolerEK Rampage VI Monoblock
    CaseC0smos 2 Modded
    Power SupplyCorsair AX1500i
    Abaidor's Avatar
    Dec 2017
    12
    260
    While I don't see the reason to upgrade as an existing Rampage VI Extreme owner what worries me is that I see a trend toward "cheaper" in ROG products.....
    This does not look as premium as the previous model unless it is indeed a more cost effective version. The armor is less complicated, has less lighting the PCI-E slots are also less (I know they were not all 16X) while all the indium plating and fancy effects are gone.
    The original was really something else, this one is.......well meh.....
    Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
    ROG Enthusiast Array thr23 PC Specs
    thr23 PC Specs
    MotherboardAsus ROG Rampage VI Extreme
    ProcessorIntel Core i7-7820X
    Memory (part number)G.Skill Trident Z RGB DDR4, 4x16GB, 3600MHz (F4-3600C17Q-64GTZR)
    Graphics Card #1Asus ROG Strix GeForce GTX 1080 Ti OC
    Storage #1Samsung SSD 960 PRO 1TB
    Storage #2WD Red 10TB
    CPU CoolerNoctua NH-D9L
    CaseIn-Win 805 Red
    Power SupplyThermaltake Toughpower iRGB PLUS 1250W Titanium
    Oct 2017
    28
    31
    yeah with a name like that you'd expect an upgrade, but it's just a budget version of R6E.
    Abaidor PC Specs
    Processori9-7940X
    CaseC0smos 2 Modded
    Abaidor's Avatar
    Dec 2017
    12
    260
    Quote Originally Posted by LiveOrDie View Post
    The only upgrade is that VRM cooling which seems to have a small fan in it and 2 pin more worth of power.
    Still....I prefer the separate VRM water block rather than a tiny FAN that will dust up and start making cringing noises down the line......
    They produce the Maximus XI formula with mediocre-to-bad VRMs and an integrated waterblock and then they go with a lousy tiny fan on a flagship high power VRM...go figure...
    ROG Guru: White Belt Array
    Mar 2018
    90
    I've been waiting for this board, but this is a little disappointing. The new Deluxe II has a 12 stage VRM unless I read it wrong. As for looks, I like this a little better than the Extreme as I really didn't care for all those lights. I may just go for the Deluxe II now as I don't see the point in spending what may be more money on this board. Plus, I also read that the Deluxe II has 3 16X PCIe slots.
    Abaidor PC Specs
    Processori9-7940X
    CaseC0smos 2 Modded
    Abaidor's Avatar
    Dec 2017
    12
    260
    It's not the lights - it's a "cheaper" cover, easier to manufacture in order to cut costs...like it or not the original requires more to be made and it shows....This looks like the cheaper Strix Boards IMHO....
    The PCI-E layout is also not good for triple slot cards.....
  7. #7
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    305
    Dominus oh Dominus, where art thou Dominus?
    Still waiting for the 68 lane W-3175X to make it's appearance also.
  8. #8
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    Quote Originally Posted by RichKnecht View Post
    I looked at the Sage boards, but couldn't find any reviews or other information about how they handled overclocking. I'm also looking hard at the Deluxe II as it has better VRMs that the previous version. Price is the same for the Sage and Deluxe II and both are readily available. As I mentioned, lights to me don't really matter and I would just turn them all off. I actually prefer the looks of the Apex, but that is long gone.
    Sage is a solid Workstation board where you can run your graphics cards in SLI (up to 4), with more PCIe slots than any other ASUS board that I know of. If it had come out before the R6E that is what would be in my rig. This new board is extremly disappointing. Dont care about loss of bling but do care about loss of PCIe slots and VROC and god only knows what else as there are no published specs. Matter of fact if this was the only ASUS board..........Id be buying Asrock or EVGA.
  9. #9
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,855
    Quote Originally Posted by G75rog View Post
    That chips MSRP is more than my entire rig, well almost.
  10. #10
    G75rog PC Specs
    ProcessorI9-7900X
    Sound CardStock
    Jan 2013
    13
    305
    Quote Originally Posted by JustinThyme View Post
    Yep. I have 13TB ($7K) of NVME in the Apex to go in it so the chip is a fraction of the total cost.
    Just think, you could run 4 2080TI's all at 16x in it!
