Page 35 of 35 FirstFirst ... 25 33 34 35
Results 341 to 344 of 344
  1. #341
    ROG Enthusiast Array Deathscythes PC Specs
    MotherboardRampage VI Extreme Omega
    ProcessorIntel Core I9-7980XE @5GHz
    Memory (part number)Trident Z RGB @3800MHz CL14
    MonitorASUS ROG PG258Q
    CPU CoolerDirect Die EK Supremacy Edge
    CasePhanteks Enthoo Elite
    Deathscythes's Avatar
    Apr 2019
    35
    Quote Originally Posted by Super Gnome View Post
    Awesome!
    Also, you say correct temperature readings... I use CPUID HWMonitor to watch my temperature readings and use custom settings with the bundled software so that the case fans (I have industrial type Noctua 140s installed) kick in and keep everything cool. Is there some reason to believe the temperature readings would not be correct? My CPU core temperatures never go above 55 degrees C according to HWMonitor, and I can hear the hum of the fans kicking in to alert me if there is a problem. Is there some reason to believe the board and/or CPU temperatures are actually hotter than the readings HWMonitor shows?
    In my case HWmonitor is completely bugged, shows temps 15°C higher than HWinfo64 if not 20.
    Also still in my case the temperature reading issues I have are due to a difference in TjMax between the 99XX and the 79XX series of chip.
    As you are running a 9980XE and not a 7980XE you are fine, but the microcode that comes with the bios 504 sets a TjMax of 110°C for my 7980XE instead of 105°C and for a reason I don't really get this messes with with temperatures reported by the cores.
    Have a look here :
    https://cdn.discordapp.com/attachmen...rocode_4Dh.PNG
    and here
    https://cdn.discordapp.com/attachmen...rocode_49h.PNG
    The later being with the modded bios
    I hope this clarifies =)
  2. #342
    ROG Guru: White Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega
    ProcessorIntel® Core™ i9-9980XE CPU @ 3.00GHz
    Memory (part number)Corsair LPX Vengeance DDR4 DRAM 2666MHz 128 GB
    Graphics Card #1Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB
    Storage #2Samsung 970 Pro 1 TB
    CPU CoolerROG Ryujin 360
    CaseThermaltake View 71 TG
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot)
    Mar 2019
    102
    Quote Originally Posted by Deathscythes View Post
    Wow! The second set of numbers are definitely a lot lower. How exactly does the modded Bios accomplish that? I also have a Rampage III Black Edition motherboard, and both of my systems' temperatures resemble the first set of temperatures above. But I have my Windows "Power Option" settings set to "High Performance" vs "Balanced" or "Power Saver." There are also custom settings that can be implemented.
  3. #343
    Apr 2019
    35
    I believe I explained the best I could in my previous post ^^ for a more detailed answer try asking in the modded bios thread :
    https://rog.asus.com/forum/showthrea...ios-Rampage-VI
    From what I understand It's a very specific issue that concerns people running Skylake X non refresh on the omega board
  4. #344
    Mar 2019
    102
    Thanks for the link. I am curious about how software (or the modded Bios) achieves lower temperatures--and wonder. I am really a noobie to such technical issues, and don't understand exactly what you mean by "non refresh." But I do have a ROG Ryujin cooler (and also a second ROG Ryo cooler in my older rig) and saw a video where the guy berates an aspect of one of these coolers' design relevant to a software issue--namely how the software reads the temperature data. Apparently it was getting the CPU temperature from the socket instead of from the CPU itself--and so it looked to be running cooler than it was really running. Anyhow, thanks for the link. I will likely pose a question there. And I am glad you solved your problem, at any rate.
