Results 1 to 3 of 3
01-08-2019 09:21 AM #1
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 2
Ethernet problem on X299-E GAMING
I chose the Asus ROG STRIX X299-E Gaming for my new rig I built about 2 months ago. After the lego class she posted as expected. OS install, drivers, usual stuff but one thing I could not understand - the ethernet port was not working. Thought it's a driver fault, so I updated the chipset and LAN drivers to the latest. Still not working. Device manager - hard forcing it to recognize the port by deleting and scanning for hardware changes. No result. Clean OS re-imaging, installed only the chipset and LAN drivers (thought it could be a problem with the driver install sequence). Nope.
I gave up on fixing it and bought an Asus - XG-C100C network card to try to workaround my issue and it solved the problem. Now I was certain it is a defect hardware.
After a long month of researching, I only found one post on a random forum that XMP profiles might disable the ethernet port if enabled. I was sure I had not enabled XMP or turbo, nor did any overclocking ever since I built it (to make sure I have a stable system before losing any warranty with overclocking). My last hope was gone.
Is it really just a defect hardware issue? Have you guys heard anything like this before? Do you know what can cause this problem?
I've contacted the retailer, we agreed on them taking the board back. Before I do so, I thought I ask the community first.
Thanks!Last edited by MenzoAS; 01-08-2019 at 12:53 PM. Reason: grammar
01-08-2019 02:27 PM #2
LiveOrDie PC Specs Motherboard ASUS RAMPAGE VI EXTREME OMEGA Processor Intel Core i9 7980XE Custom IHS @ 4.6Ghz 1.23v Memory (part number) G.Skill Trident Z RGB F4-3000C14D 64GB Graphics Card #1 AORUS GeForce RTX™ 2080 Ti XTREME WATERFORCE WB 11G Monitor LG 4k 43inch Storage #1 Samsung 960 Pro NVME 512gb Storage #2 Samsung 850 Evo 1TB x 2 CPU Cooler EK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM Case Corsair Obsidian 500D SE ATX-E Modded Power Supply Cooler Master Vanguard Series 1000W Keyboard Logitech G910 Mouse Logitech G900 Headset Razer Tiamat 2.2 v2 OS Windows 10 x64 Network Router NetGear
- Join Date
- Dec 2011
- Reputation
- 41
- Posts
- 1,680
RMA the board it sounds like its faulty.
01-16-2019 11:42 AM #3
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 2
Thank you for your advice, will do so. (Sorry for the late response, just got back home from a trip.)
Currently talking to the retailer. I'll post more info once I got a new one / it back.
