Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Enthusiast Array
    Jan 2019
    41
    Fan speed control in Windows.
    Is there an application where I can monitor fan speed control, in Windows? Not through the BIOS.
    I don't want to change the fan speed. I just want to know how fast it's running.
    Is there some utility from Asus Crosshair motherboards, that lets me do that?
    Or do I have to use a 3rd party application?
    Jan 2019
    41
    Also, has anyone tried using a fan splitter?
    I have 4 fans, but there's only 3 chassis fan ports.
    I bought a fan splitter, but haven't tried it yet.
    Jan 2019
    41
    Quote Originally Posted by MoKiChU View Post
    You can use HWMonitor (by the creators of CPU-Z) : https://www.cpuid.com/downloads/hwmo...nitor_1.38.exe
    Thanks.
    After seeing your post, I installed both Corsair Link (because I have a Corsair PSU), and HWMonitor.
    Comparing the two, I was able identify which fan was which, on each software.
    A few questions.
    From Corsair Link, why does it say my DRAM frequency is 1463.2 MHz? I set it to 2933 MHz in the BIOS. 1463.2 is roughly 1/2 of 2933, but I don't know if that explains it.
    I have 2x8GB modules.
    Also, it says my CAS latency is 16. Why is that? I'm pretty sure it said 15 in the BIOS too, but I can check again.
    My RAM is supposed to be:
    Timing 15-15-15-35
    CAS Latency 15 .
    Using HWMonitor, under Clocks, it says the Memory is at 7001 MHz. Where is it getting that from? How does it get 7001? Again, my RAM is supposed to be running at 2933.
    Thanks.
    I can post screen shots of anything if necessary.
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Dump HWMonitor it is waste of time on Ryzen/Threadripper, you will see monitoring data that is not occurring.
    By default Gear Down Mode is Enabled, it will round up odd CAS to nearest even.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    New ROGer Array
    Aug 2018
    2
    HWiNFO64
    or
    AIDA64
    ROG Guru: Green Belt Array panzlock PC Specs
    panzlock PC Specs
    Laptop (Model)ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99
    MotherboardASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming
    ProcessorIntel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700
    Memory (part number)8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16
    Graphics Card #1EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56
    Monitor32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ
    Storage #1Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2)
    Storage #2Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
    CPU CoolerDeepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire
    CaseAntec Sonata, Deepcool Dukase V1, Deepcool Dukase V3
    Power SupplyATX 650, EVGA SuperNOVA 850 P2 (X2)
    Keyboard Logitech K220, MSI Interceptor DS4200 (X2)
    Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus
    Headset/Speakers Logitech Z313, Logitech Z506 (X2)
    OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
    panzlock's Avatar
    Nov 2016
    54
    702
    Never mind. Misread post and responded inaccurately.
    I wish it were this easy to edit marriages.
    I'd like to deploy my troops in her country.
  7. #7
    Jan 2019
    41
    Quote Originally Posted by hhamil1 View Post
    HWiNFO64
    or
    AIDA64
    HW Info seems pretty cool.
    I'm still not sure why both Corsair Link, and HWInfo, report the RAM frequency as 1463.2 MHz. Why doesn't it say 2933, since that's what I set it in the BIOS?
  8. #8
    Jan 2019
    41
    Does HWInfo display the fan speeds anywhere?
    EDIT: I found it. I have to click on the Sensor button on the button bar.
  9. #9
    ROG Member Array Ashwind PC Specs
    Ashwind PC Specs
    Motherboardmaximus IX formula
    Processorintel I7 6700K
    Memory (part number)64 gb corsair dominator 3200
    Graphics Card #11080 ti strix
    Jun 2016
    28
    14
    Quote Originally Posted by nuraman00 View Post
    The DDR in DDR4 stands for double data rate so what link and HWinfo are displaying the single speed of your ram, most programs seem to diplay it the same way, so your ram is pretty much where it should be.
  10. #10
    Jan 2019
    41
    Thank you!
