Results 1 to 3 of 3
    New ROGer Array
    Jul 2018
    3
    GL702VM Won't POST
    My laptop ROG STRIX GL702VM won't POST. Screen is black, with no ROG logo splash screen. LED indicator light for battery (charging) and power works, but the storage LED doesn't blink even once. I tried removing battery and CMOS battery with no luck. Is there another way to reset BIOS CMOS?
    I tried holding power button for 2 minutes again no luck. I tried removing both RAM modules and it gives flashing green LED indicator. Tried one of either RAM gives no flashing green LED, but still won't POST. I also tried swapping NVMe and HDD for boot drives and also Windows 10 bootable USB, but it doesn't look useful, since it won't even load the UEFI BIOS. The CPU fan is active, and all the USB ports output power, however the keyboard is off (Backlight is off and CapsLock does not toggle). I tried plugging external USB keyboard, but it isn't detected.
    I'm out of ideas. I called Customer Service for repair cost, he quoted $600 USD. That's insane! If anyone ever solved this problem, please let me know.
    Last edited by ReptillusMax; 01-15-2019 at 02:56 AM. Reason: Updated troubleshooting attempts.
    ROG Guru: Orange Belt Array FULLMETALJACKET7's Avatar
    Mar 2018
    45
    365
    How did it happened? Like all of the sudden or after an update, hardware change or something like that?
    New ROGer Array
    Jul 2018
    3
    Quote Originally Posted by FULLMETALJACKET7 View Post
    A BIOS change was made to set the boot order, which included turning off Safe Boot to enable for an older OS boot.
Tags for this Thread
