01-15-2019 07:48 AM - last edited on 03-06-2024 08:56 PM by ROGBot
01-15-2019 10:59 AM
01-15-2019 11:26 AM
01-15-2019 01:21 PM
01-15-2019 01:31 PM
Somethingwhatever wrote:
36-41c at Idle
Ambient temp is about 20c
I have one fan in the back blowing out 2 fans in the front sucking in.
I took no part in building this computer, it was custom built through ibuypower, but the cooler is mounted properly. I can't speak to the thermal paste they applied or how much/little.
AIO pump seems to be working fine. There is no "monitoring software" for thermaltake. You can only control the fans and it shows you the temp of the cpu. Fan's are maxed out at ~1600rpm. The pump is 3000rpm according to the specs. The radiator is top mounted though so the pump has to fight gravity.
Yes i'm very stoned.
Marriage is a contract you should never sign.
01-17-2019 08:50 AM
01-17-2019 09:56 AM
01-17-2019 10:41 AM
01-17-2019 12:31 PM
