Voltage readings
Kratzr
I have a 9900k with the ASUS MAXIMUS XI FORMULA.
I use 1.295V on manual mode for 4.9GHz Core Clock and 4.7GHz Cache Clock.
HWiNFO64 says that the CPU idles at 1.23V and under load it reads 1.28V.
CPU-Z reads 1.28V idle and 1.21V under load.
Wich of these two programs is trustworthy?
Rob_W_
Level 12
Hi Kratzr .
Are you running them both together? As they will both be trying to read the same sensor.
Try running them separately *to get an accurate reading, multiple monitoring generally gives false readings.
