ROG CROSSHAIR VI EXTREME Chipset Driver
AlexB121
Version 18.40.02
2019/01/15248.79 MBytes
AMD Chipset Driver V18.40.02
AMD Chipset Driver V18.40.02 for Windows Win10 64bit.
Corrupted files will not unzip
20 REPLIES 20
majorhi
Same issue here myself and have not found another location in which to download from. Nothing on the AMD site either. What gives?
Rewerend
Same for CH VII some days ago I found that driver too on my support page - install fail, now the driver seems to be updated but I don´t want to install them. The driver number is different with AMD one, so looks strange...
AlexB121
Is asus going to fix this soon ?
Hurricane28
Seen it too for my CH7 wifi. Doesn't mater though because there is no new chipset driver on the AMD website either.
AlexB121
I keep Chatting with asus support they said it will be fixed within 24 hours this was yesterday ... Still nothing
AlexB121
2 Days after they said 24 Hours and still nothing
I took the risk and installed it on my CH7, haven't had any problems with it yet but I'll update this comment if things go wonky.
AlexB121
You installed it even with the extract error ?
I figured the install would fail if the problem was really significant. Plus I've got a lot of backups. Plus I'm 90% sure I'm a dumb ass on the literal genetic level.
