Results 1 to 6 of 6
    New ROGer Array walrbe PC Specs
    walrbe PC Specs
    MotherboardMaximus XI Hero
    Processori7-8700K
    Memory (part number)G Skill TridentZ RGB F4-3200C16-8GTZR
    MonitorPhilips BDM3270
    CPU CoolerDeepCool Castle 280 AIO
    CaseFractal Design R6
    Power SupplyAntec Gamer power 520W
    OS Windows 10Pro
    Nov 2018
    43
    Red face Observations going from 5Ghz to 5.1Ghz on 8700k
    I wanted test 5.1 today and see where I got to. Well didn't get there. Could not run Cinebench completely.
    Using 1.38 Volts and LLC 6. I'm not sure pushing voltage any higher could achieve much even if stable as my temps hit high 90's. I wonder if going higher on LLC will help?
    At 5ghz I'm using 1.3 Volts and perfectly stable across many bench tests. Looks like I will have to settle for 5.0. Which is fine, I was just pushing the system a little further to see what would happen.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,546
    Sounds like your chip is not dlidded by the temperature your reporting, temperature will be the limiting factor. Here is Silicon Lottery's stats for delidded 8700K chips they sold.
    walrbe PC Specs
    Processori7-8700K
    OS Windows 10Pro
    Nov 2018
    43
    Quote Originally Posted by Menthol View Post
    Yes not dellided. Those stats for delid chips require a lot of voltage for the relative overclocks, for instance why is 5Ghz 1.4 V, it should show lower than non-delid. I probably delid eventually but would like to see at least 5.2 on my chip, otherwise its not much to gain for real world use.
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,546
    I don't think they bin each chip for minimum voltage at each speed.
    I own one of there 5.3 chips and it comfortably runs at 5.0 on less than 1.3 volts on a X Apex with cache speed boosted and high speed memory
    ROG Junior Member Array IntelVN PC Specs
    IntelVN PC Specs
    MotherboardROG MAXIMUS XI HERO (WI-FI) Call of Duty
    Processori5-9600k
    Memory (part number)G.SKILL Trident Z RGB 16GB 3000C15D
    Graphics Card #1ROG Strix GeForce® RTX 2070 OC
    MonitorAcer VG270UP
    Storage #1Samsung Evo 860 EVO 250GB
    Storage #2Samsung Evo 860 EVO 500GB
    CPU CoolerAIO NZXT Kraken X62
    CaseNZXT H500i
    Power SupplyCorsair RM750x 80 PLUS® Gold
    Keyboard Corsair K68 RGB Blue switch
    Mouse ROG Pugio
    Headset Kingston HyperX Cloud 2
    Mouse Pad Logitech G440
    OS Windows 10 Pro x64
    Accessory #1 Intel Optane 32GB
    Accessory #2 WD Red Pro 4TB
    May 2015
    3
    we have recommend for 9600k ?
    walrbe PC Specs
    Processori7-8700K
    OS Windows 10Pro
    Nov 2018
    43
    Woohoo got 5.1
