Results 1 to 3 of 3
    ROG Enthusiast Array idahosurge PC Specs
    idahosurge PC Specs
    MotherboardRampage VI Extreme
    Processor7820X @ 46 GHz / 3200 MHz
    Memory (part number)G.Skill F4-3600C15D-16GTZ (2 Kits 32 GB)
    Graphics Card #1Zotac Amp Extreme GTX 1080 Ti
    MonitorAlienware AW3418DW 34" GSync
    Storage #1OS - Samsung 850 Pro 513 GB
    Storage #2Backup - Samsung 850 Pro 1 TB
    CPU CoolerThermalright Archon IB-E x2
    CaseCooler Master HAF X
    Power SupplyCorsair AX860i
    Keyboard Corsair K95 RGB Platinum
    Mouse Logitech G703 Lightspeed
    OS Windows 10 Pro - 1709
    idahosurge's Avatar
    Nov 2017
    51
    BIOS Q-Fan Control Temperature Question
    What temperature is the BIOS Q-Fan Control monitoring?
    Is it the same CPU temperature that AISuite 3 Fan Xpert 4 monitors?
    It is getting close to the time that I will be forced to update Windows 10 to 1803.
    I only use AI Suite 3 for Fan Xpert 4 so I want to go ahead and uninstall AI Suite 3 and switch my fan control to BIOS Q-Fan Control, but want to know what temperature Q-Fan Control monitors.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    164
    7,454
    Yes, it’s the same temp that is used by Ai Suite and Fan Xpert.
    idahosurge PC Specs
    idahosurge's Avatar
    Nov 2017
    51
    Quote Originally Posted by Raja@ASUS View Post
    Thanks Raja!
