Results 1 to 4 of 4
    Ball Python Enthusiast Array
    Dec 2015
    16
    How to Manually Set Fan Speed to 100% In ASUS G20CB?
    Hello, this is the exact issue. I bought Samsung NVME Evo 970 and its idle temp is 64 - 69 C. This is bad as it does not properly function at 70 C. Under load for only 3 measly minutes it breaches 80 C, which is quite bad.
    I would like to set my fan's speeds to be 100 %, all of the time, but I am not sure how to manually set them. The BIOS option only goes up to 600 RPM, but when I try to exit it says "Save & Reset" so I dont know how to save without this strange 'reset' and I also want my fans 100%, not like, 10%. Currently the fans don't respond to the temperature of the SSD whatsoever.
    AFAIK the computer comes with Aegis Suite II, Command, and Game Alive, but not AI which people say allows for custom fan temps. I really need some program to get these speeds at 100%. Thanks!
    The PC is ASUS G20CB. It has i7 6700, modified H97 or H110 mobo, 16 GB SODIMM DDR4. It came with a 970.
    ROG Member Array
    Oct 2016
    6
    Hi, did you find an answer other than turning off the auto speed and letting the fans spin at max?
    i got to 80 degrees too. Turned the chassis to manual and left cpu to auto. i also put my gpu fan onto 75% manual. Temp at the moment is 64 degrees.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Save and reset is not strange, it's normal. It means save the settings and reboot the computer with new settings.
    Davemon50
    ROG Member Array
    Oct 2016
    6
    I've got the Samsung Evo 970 Plus and fitted into one of these when i started having temperature issues.
    There is no way I could fit a 40x40 fan anywhere to help with airflow without some serious metal work on the inside of the case.
    I have CPU fan running on manual so it's 4000rpm constant and put the 1070 founders onto manual 50% too giving 2000rpm. HWINFO temps 57 max 54 min 56 average.
    I'm pretty sure the chassis fan was giving better cooling when enabled so going to reverse in the bios and take temps again
Tags for this Thread
