Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Guru: Green Belt Array hexaae PC Specs
    hexaae PC Specs
    Laptop (Model)ASUS Gaming Laptop GL703GS
    MotherboardIntel HM370 Cannon Lake-H (310)
    Processori7-8750H
    Memory (part number)32GB DDR4 @2666MHz (dual-channel)
    Graphics Card #1NVidia GTX 1070 8GB
    Monitor1080p 144Hz 17" G-Sync AUO B173HAN03.2
    Storage #11TB SSD Crucial MX300
    Storage #2NVMe Samsung PM916
    Mouse ROG Strix Carry Wireless-BT mouse
    Mouse Pad MouseRug collection
    Headset/Speakers Realtek HD (ALC295)
    OS Windows 10 PRO x64
    Accessory #1 XBox One Bluetooth gamepad
    Accessory #2 Hori Fighting Stick Mini
    Accessory #3 4K Blu-Ray UHD USB Archgon Star
    hexaae's Avatar
    Feb 2015
    27
    668
    Opening GL703GS and repasting CPU and GPU voids the warranty?
    A simple question: Opening GL703GS to repaste CPU and GPU voids the warranty?
    Why I'm asking? Because after 2nd RMA and new mobo it returned with very high temps. CPU before, in fans Balanced mode: 85-88-91 °C, now after 2 mins some cores randomly and easily reach 96-98°C. Also GPU before RMA was max 82°C now 87°C after 2 mins playing games like Rise of the Tomb Raider.
    ROG Member Array
    Dec 2018
    8
    Also interested to know this. I'd like to repaste using Thermal Grizzly Kryonaut, a non conductive paste.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    AFAIK there are no seals so if you dont blow it and destroy anything they wont question it. In the US market they have removed any warranty disclaimers on broken seals BUT the user or unauthorized shop that is deemed to have caused damage voids the warranty.
    hexaae PC Specs
    Processori7-8750H
    hexaae's Avatar
    Feb 2015
    27
    668
    Yep there are no seals...
    hexaae PC Specs
    Processori7-8750H
    hexaae's Avatar
    Feb 2015
    27
    668
    Quote Originally Posted by Wrinkly View Post
    Same here.
    At present AIDA64 or HWiNFO always report some Thermal Throttling for me, and some cores randomly reach up to 96°C, or even more!
    Sent it in RMA and returned with the same temps.
    Even though I've read some who consider these temps "normal" I'm quite sure they aren't since I myself got max 88°C with my previous (faulty) motherboard (sent it in RMA 3 times already for other issues!!) and videos like this confirm 88-89°C as a "ok max temp", not 96°C+:
    (see at 36:24)
    ROG Enthusiast Array Queen6's Avatar
    Jun 2018
    55
    85C Max here and that's at a sustained 3.9GHz, admittedly it's undervolted by -140mV. Temp can spike higher, however once the cooling solution spools up 85C is maximum temp on the cores, ambient generally 24C/26C. Don't see any issue with repasting, just need to be careful and do your homework first.
    Q-6
  7. #7
    hexaae PC Specs
    Processori7-8750H
    hexaae's Avatar
    Feb 2015
    27
    668
    Looks like GL703GS (i7-8750h + 1070 8GB) has white paste on the vrm small chips instead of pads... should I replace that with new thermal paste or can I use Arctic pads 0.5 in your opinion? I'm going to clean up the white paste and use pads only for the vrm chips. Or white paste on vrms should be replaced only with other thermal paste because of the high temps?
    Looks like this (GL702VS previous model):
    https://youtu.be/7glBCZr8ntI?t=528
    (min 8:46)
    Queen6 can you please test AIDA64 System Stabilty stress test and flag everything including 'Stress GPU', except 'Stress local disks'. Do you have some Thermal Throttling? And what's your max CPU temp after the test for 1 minute (see Statistics tab)?
    At the beginning of the test or 10 secs later I have a variable Thermal Throttling spike (sometimes 5%, sometimes 18%, CPU max reached 93-95°C), then the temps are stabilized lower to 84-88°C... I have to understand if this is normal for GL703GS.
  8. #8
    Jun 2018
    55
    Quote Originally Posted by hexaae View Post
    (min 8:46)
    Sorry as this system for work purpose and a function of Revenue, I only install what I need. What I can do is this:
    2:50 minutes into Corona Renderer & OCCT GPU, Max peak CPU temp 93C, once the cooling solution spools up 79C. I can push it harder as currently CPU PL-2 power limit is in effect, unlocking the power limits performance is much the same with a constant 60W draw on the CPU. I don't worry about spike in temperature, more max temperature under sustained load
    Same this time with Prime95 Small FFT, CPU max power draw 85W at full Tubo, unlocking the PL-2 limit it will hold a full 3.9GHz across all cores indefinitely, although likely not prudent to do so.
    I'll look to see if I can find a higher load, although so far nothing has remotely phased the notebook. Throttle indicator in ThrottleStop is trigged by the PL-2 limit kicking in, not thermals or power supply.
    Ambient 24C, stock paste, computer up for 12 hours in continuous use.
    What you might be seeing is the PL-2 limit kicking in at the 28 second mark, this will enforce a 45W max power draw for the CPU, equally this is completely reproduceable & systematic seeing a reduction in CPU temp, frequency & output.
    Q-6
  9. #9
    hexaae PC Specs
    Processori7-8750H
    hexaae's Avatar
    Feb 2015
    27
    668
    Thank you very much, so you too have small spikes of 93-96°C max. That's what I wanted to know because here is the same: with undervolt I'm around 80-88°C with almost every game (including Raise of the Tomb Raider or Witcher 3 etc...), but through AIDA64 Extreme (free) using the 'System Stability Test', or other stress tools, it can actually reach spikes of 93°C or more.
    It's normal behaviour then. I asked this because many GL703GS users after repaste claim they are always under 88°C which sounded a bit untrue or "not exact" to me.
    Thanks for your tests!
  10. #10
    hexaae PC Specs
    Processori7-8750H
    hexaae's Avatar
    Feb 2015
    27
    668
    BTW, ASUS Romania on YouTube commented in one video that actually opening and repasting these laptops does void the warranty.
