Results 1 to 8 of 8
    New ROGer Array
    Jan 2019
    1
    Please Help me technical support
    System Info
    INTEL 7980XE
    Rampage VI Extreme Board
    Corsair Vengence 16GB*4 EA
    M.2 NVME SAMSUNG 970 PRO 1TB * 3 EA
    EVGA 1080TI FTW3
    OS / Windows 10 RS5
    Bios 1603
    Hi, technical support.
    Here's a raid inquiry for the Rampage VI Extreme Board.
    I am 970 pro 1tb in slot DIMM.2_1. 970 pro 1tb *2 EA is used in DIMM.2_2 expansion card.
    However, the nvme card of 970 pro * 3EA cannot be set in the bios screen. It's
    EX) When setting the Raid, 3TB Nvme
    question
    1. Is this not set?
    2, Then, can I set the VROC Prime key?
    Select on question 2
    [YES] Use the VROC Prime key to select Samsung 970 Pro *3 EA Can I set it through the VROC Prime key?
    [NO] If setup is not possible through the VROC Prime key Can't you set the original settings on the board bios screen?
    3. If question 2 says YES, VROC Prime key is Are all Intel products the same size?
    Select from Question 3
    [YES] Please link to the site where you purchased the product.
    [NO] Then, please link me to the site where I should buy the product.
    4. If question 2 says NO,
    I am asking if Samsung 970 Pro *3 EA can be set to Raid through a future BIOS update.
    Please give me an answer as soon as possible
    ROG Guru: Brown Belt Array Brighttail PC Specs
    Brighttail PC Specs
    Laptop (Model)Asus G751JT
    MotherboardAsus x299 Rampage VI Extreme
    ProcessorIntel i9-7900x
    Memory (part number)Corsair Dominator Platinum SE 3200Mhz 4x8
    Graphics Card #1MSI GTX 1080TI
    MonitorAcer XB321HK (4k,IPS,G-sync)
    Storage #1Intel 900p (Boot) 2xSM961 (RAID 0) Games
    Storage #2Samsung 850 Pro 512GB - WD Black 4TB
    CPU CoolerCustom Water Cool
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX 1200i
    Keyboard Corsair Platinum 95
    Mouse Asus SPATHA
    Mouse Pad Corsair MM800
    Headset/Speakers Kanyo Y5
    OS Windows 10 64 bit
    Accessory #1 2 x Alphacool Full Copper Radiator 420mm/280mm
    Accessory #2 Monsoon MMRS reservoir w/ 2 x D5 Vario Pump
    Accessory #3 Monsoon Free Center Compression Fittings
    Sep 2014
    33
    1,336
    Simply put, you cannot use VROC using any drive other than on select Intel drives. VROC is not possible on the x299 platform using Samsung drives UNLESS you have a XEON processor and have the appropriate VROC key.
    You will also not be able to set up RAID as a bootable drive using the Samsung drives. You can set RAID using the Samsung drives if they are going to be non-bootable drives and if that is the case it is better to use normal Windows RAID.
    I suggest you scroll back a few pages on this forum to see the discussions on VROC RAID and what is required. As it is right now your system will not be able to use VROC at all.
    The DIMM.2 slot shares resources with I believe the last PCI-e Slot, so if you have something in there you may not be able to use both slots on the DIMM.2. You definitely won't be able to do anything with VROC as stated earlier.
    Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
    MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
    Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
    Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
    Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,855
    You can do a bootable raid, non VROC with two of the drives with one in DIMM.2_2 being the one on the outside and the one under the armor. DIMM.2_1, the one on the inside, does in fact share with the bottom PCIE slot aka PCICEX16_4 abd cab be set up as stand alone or as VROC with an intel M2 when in CPU mode with another intel drive in an M2 Adaptor installed as an AIC.
    As BT already said no Intel Drives, no VROC.
    Also be aware this isn't a tech support site, just and ASUS sponsored enthusiast forum. If you have a general need for ASUS tech support the best bet is to log a ticket online in the support page where you register your products.
    Brighttail PC Specs
    Mouse Asus SPATHA
    Sep 2014
    33
    1,336
    Quote Originally Posted by JustinThyme View Post
    Ah yes that is right you can do it but you won't do it through the CPU lanes, but it will be limited in bandwidth if I remember correctly, like in the Z170 and z270 iterations.
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,855
    Yep, can be done but useless as a single drive 960Pro or 970Pro speeds already pretty much max out the 4 lanes of the DMI bus. You actually hurt your performance for nothing as there is very little gain in sequential like maybe from 3500MB/S to 3700MB/S but due to the raid latency you lose in Q1 random down from like 55MB/S to 40MB/S or less.*
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3301 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 49
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2021 Insider Preview 21359.1
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    75
    643
    There was a new toys from Intel for VROC build not far from here. Just waiting to see performace of these toys.
    https://www.intel.com/content/www/us...emory-h10.html
  7. #7
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,855
    Quote Originally Posted by restsugavan View Post
    Well that doesn’t say very much. My guess is flop city. The 905P M.2 sticks actually offer something you can put in a HyperX16 card and do a VROC array with but reviews are showing them slower than U2 and AIC counterparts. **
  8. #8
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    75
    643
    That because 905P M.2 380GB stick was perform below other models on U.2 and PCIe SSD form factors. I think H10 model that combine 32GB Optane + 1TB 660p QLC model VROCs setup may interesting than 905P M.2 380GB VROCs system . We must waiting and see how Intel Rapid
    Storage Technology 17.0.0.1072 + Optane Accelerator 17.0.0.1072 perform together on these toy.
