Results 1 to 10 of 10
    ROG Member Array homdax PC Specs
    homdax PC Specs
    MotherboardAsus ROG Strix X470-F Gaming
    ProcessorAMD Ryzen 5 2600X
    Memory (part number)32 GB G.Skill F4-3200C14-8GVH
    Graphics Card #1Asus ROG Strix GTX 1060 6GB
    Monitor2 x Dell U2718Q 4K
    CPU CoolerAMD Wraith
    CaseCorsair Carbide Air 540
    Power SupplyCorsair RM850X
    Keyboard Asus ROG Strix Flare
    Mouse Logitech G703
    Headset Kingston HyperX
    Mouse Pad Logitech Powerplay
    Headset/Speakers Logitech Z623
    OS Windws 10 Pro
    Network RouterAsus RT-AC87U
    Accessory #1 Kayboard ASUS ROG Strife
    homdax's Avatar
    Mar 2018
    21
    Question What fans would work with Aura?
    I recently changed my chassi from a closed tower with no glass panels or visible areas to a Cube chassi with see through fan mesh, glass sides and stuff. In doing that my plan was not so much a component upgrade, but a switch of fans and getting some lighting visible using Aura.
    Mobo: ROG STRIX X470-F GAMING
    GPU: Strix Geforce 1060
    KeyB: Rog Strix Flare
    All AURA compatible.
    For starters I bought a triple set of Corsair 120mm fans with a RGB LED controller, I just assumed it would work connecting them to the motherboard, but turns out the RGB controller is connected with separate cabling so not working with only the fans connected to mobo.
    What fans with integrated LED RGB would work with Aura using the Aura controller software to handle the lighting effect?
    Another thing, I could use a tip for additional fan mobo connectors, normal Y cables are not enough.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    Corsair fans won’t, they have to use the Corsair commander or lighting node. There are lots that do but not as awesome as the LL series. If they are guaranteed to work with aura the webpage will have an aura logo on it.*
    homdax PC Specs
    Mouse Logitech G703
    OS Windws 10 Pro
    homdax's Avatar
    Mar 2018
    21
    No examples?
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,547
    The RGB fans that came with my Lian Li case work with AURA, as Justin said, google fans AURA compatible
    Justin (I prefer the LL fans myself) very good airflow for noise ratio
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    Quote Originally Posted by Menthol View Post
    I put in just a few of them......half of the push pull, the other half are the ML series, no point in having lights you can't see and they also have a nice static pressure and flow to noise ratio. 20 fans in all
    homdax PC Specs
    Mouse Logitech G703
    OS Windws 10 Pro
    homdax's Avatar
    Mar 2018
    21
    Sorry, I see now you wrote LL indicating Liang Li...
    That's many fans, how do you get power to them? Fan controllers?
  7. #7
    homdax PC Specs
    Mouse Logitech G703
    OS Windws 10 Pro
    homdax's Avatar
    Mar 2018
    21
    Ok, after some searching I have come to realize that its a bloody mess to find out.
    The info on Asus site is only available as you watch one of the movies, and thus you get In-Win. After some additional searching I found that many, if not all, many of the CoolerMaster RGB fans are Aura compatible, with the Aura logo on the fans description on CM's site. After that we do of course have Lian-Li as well, but looking on the site I see the Aura logo only on the Bora-Lite series.
    There is of course another aspect in this, if you are cunning enough to determine from the technical specifications that the Fan should work with Aura, regardless of Aura logo on their site, then feel free, buy it. I am not that cunning, yet.
    I find the lack of correct information on behalf of Asus disturbing. After all, the fans must have been approved for the Aura logo rite?
  8. #8
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,858
    RGB for the most part is RGB. More will work than do not. You just have to make sure that they are not like Corsair and have propreitarty connectors. Truth be known you could get the Corsair fans to work if you could figure out which pin does what, cut the ends off and install different ends but thats too much trouble when you and just but their controller which quite frankly blows aura out of the water. Then consider 5V addressable vs 12V non addressable.
    For my fans the RGB is done with lighting nodes from ccorsair each node has 2 channels, each channel can do 6 fans or sections of strips. The biggest PITA is making sure you get them in the correct order. Tha fans themselves are all PWM in 3 channels and PWM D5 pumps on a 4th channel all being controlled by an aquaero controller becuase Ive found nothing else that will work like it does. Tight curves and flawless........dayum, sounds like a a date!! LOL RGB is off the chain now. Went from non existent to overly abundant is 0.25 seconds. First thing you have to think about is the fans purpose as in moving air. RGB is ancillary
  9. #9
    homdax PC Specs
    Mouse Logitech G703
    OS Windws 10 Pro
    homdax's Avatar
    Mar 2018
    21
    Well, fan function are of course a must, but I have a cozy corner for my current desktop (Corsair 540), modded it a bit for more lighting so it will become a bit of a colourful furniture in a corner in my room. Never had that before so its kinda fun. Made an order for two sets of 120 and 140 mm fans from CoolerMaster, even a CPU fan, the Master Air G100M RGB. Can use the Corsair ones somewhere else...
  10. #10
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,547
    The LL fans are Corsair not Lian Li.
    Damn Justin, a person could be hypnotized by those lights
