Results 1 to 3 of 3
    ROG Enthusiast Array
    Jul 2018
    31
    Audio static/ distortion left side on HD audio header (front panel)
    I have this weird issue with static/distortion on the left channel of any headphones using the onboard front HD audio header/port. The port on the I/O panel works fine. If i change the bitrate to 192k 24 bit or 192k 16 bit the noise goes away. its only present at the default 48k 24bit and the 48k 16 bit options. i tried connecting a different front audio panel to the header to see if it made any changes but it didn't. You think this is a defective board or just a software/hardware issue
    Hero XI
    Jul 2018
    31
    It looks like asus doesn't update there audio drivers on the support page and you have to find them in a forum thread (kind of stupid) after updating issue still there
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,854
    Never been a fan of the on board audio for any board. Its mostly the amps. Havent even found a sound card that meets my demands. I use the optical out and an external DAC that reproduces beautifully and sits on my desk in front of me for volume control going to speakers and it also has a headphone jack.
