Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Member Array Deltaphi PC Specs
    Deltaphi PC Specs
    Laptop (Model)Microsoft Surface Pro
    MotherboardASUS Maximus XI Extreme
    ProcessorIntel i9-9900K
    Memory (part number)CMW32GX4M4C3200C14
    Graphics Card #1ASUS ROG Strix 2080 Ti Gaming OC
    Sound CardASUS Xonar DX
    MonitorASUS PG279Q
    Storage #1Samsung 970 Pro 512GB, 970 Evo Plus 1TB
    Storage #2Samsung 850 Pro 256GB x 2
    CPU CoolerCorsair Hydro H110i Extreme
    CaseCorsair Obsidian 650D
    Power SupplyCorsair AX1200i
    Keyboard Corsair K70 RGB Rapidfire
    Mouse Corsair M65
    Headset Corsair Void Pro RGB USB
    Mouse Pad Corsair MM300 Extended
    Headset/Speakers Yamaha 2.1 Speakers
    OS Windows 10 Pro 64 bit
    Network RouterSpeedport Entry 2i
    Accessory #1 HDD WD Gold 2TB, WD Black 2TB + 3TB, WD My Book 8TB
    Accessory #2 Canon Pixma iP6700D
    Accessory #3 Canon CanoScan LiDE 210
    Deltaphi's Avatar
    Jan 2019
    5
    Smile Maximus XI Extreme Dimm.2 RAID 0 with Samsung 970 Pro nvme SSDs
    Hello to anyone who reads this.
    I would appreciate any help in clarifying whether you can use Samsung SSDs on the DIMM.2 slot for RAID 0 bootable configuration, or does it work only with Intel branded SSDs.
    Thanks for any help.
    Dimitris
    ROG Guru: Yellow Belt Array btrach144 PC Specs
    btrach144 PC Specs
    MotherboardASUS Maximus XII Extreme
    ProcessorIntel i9 10900K @ 5.1 GHz
    Memory (part number)32 GB G.Skill DDR4 4000MHz C17
    Graphics Card #1EVGA 2080Ti FTW3 Hydro Copper
    MonitorASUS PG27UQ
    Storage #1x2 Samsung 970 Pro 1 TB in RAID 0
    Storage #2Samsung EVO 850 1 TB
    CPU CoolerCustom EK loop
    CaseCorsair 750D
    Power SupplyROG THOR 1,200W
    Keyboard Logitech G915
    Mouse Logitech G903 PowerPlay
    Headset Logitech G935
    Mouse Pad Logitech Powerplay
    Headset/Speakers Logitech Z905 5.1 surround
    OS Windows 10 (2004)
    Network RouterASUS AX11000
    Jun 2014
    140
    Yes, Samsung SSDs will work. It just uses Intel RST to create and manage the RAID 0. Most NVMe drives should work without trouble. The main goal is to have 100% matching NVMe drives.
    Deltaphi PC Specs
    MonitorASUS PG279Q
    Mouse Corsair M65
    Deltaphi's Avatar
    Jan 2019
    5
    Talking Thanks
    Quote Originally Posted by btrach144 View Post
    Thank you for the prompt reply
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    Intel SSDs only apply to VROC so you don’t have to worry about that. My question is though why are you going raid0? If it’s for a performance boost you won’t see it on NVME drives as they already saturate the DMI bus as standalone. You will also take a hit on the low que depth speeds due to the latency of raid.*
    Deltaphi PC Specs
    MonitorASUS PG279Q
    Mouse Corsair M65
    Deltaphi's Avatar
    Jan 2019
    5
    Raid nvme
    Quote Originally Posted by JustinThyme View Post
    I was planning to use cpu lanes dropping gpu to X8 as it doesn't affect frames so much. With 980 Ti I was running on X58 board X16 pcie 2.0 which is about the same as X8 pcie 3.0. Do you think it is a bad idea to go this way?
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,857
    No, you’re OK at X8 on the GPU as the 2080Ti is the first card to saturate PCIE Gen 3.0 X8 bandwidth and only by a little. You won’t be able to do raid 0 with one in the CPU and the other on the PCH though. *Like I said though it’s pointless. If your board allows both on CPU which I don’t think it does you still can’t raid them up and make it bootable. Only way to do that is on X299 and it has to be Intel drives.
  7. #7
    Deltaphi PC Specs
    MonitorASUS PG279Q
    Mouse Corsair M65
    Deltaphi's Avatar
    Jan 2019
    5
    Smile Raid 0 Dimm.2
    That brings this thread to my original question that started it:
    Bootable Raid 0 on Dimm.2 using 8 CPU lanes for 2 Samsung 970 Pro NVMe SSDs, dropping GPU slot to X8 is not possible? or is it?
    The motherboard User Manual has this on the Dimm.2 section:
    Thanks for your help.
  8. #8
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,857
    Booting from CPU lanes with anything but Intel drives in VROC is not possible. Software raid only with non intel drives. *Trust me when I say all this has been tested and beaten to death. Myself and several others tried every configuration possible. *This board and it’s design are an intel chipset so they control the patent and implementation. At launch they wouldn’t even get off of what VROC keys would work and many were tried. Only one will work but it’s not needed for bootable raid zero. BUT Intel drives are mandatory. You want the speed you have to pony up. Two 480 GB drives are not all that much more than 2 1TB Samsung 970 pro drives. Yes get half as much but that’s just the way it is. The intel drives can’t be touched to random low que depth performance which is the most important of heavy workloads and OS operations. Samsung owns the large file sequential reads. My rig is set up with intel drives for the OS and general software while all games and anything with large files gets installed to a single Samsung 1TB 960 pro in DIMM.2_1 set to CPU as the source. *I’m about to change it all though as after going to 2080 Ti cards they actually do saturate X8 bandwidth so I’m ditching VROC completely and using a single intel U2 drive, changing the DIMM.2_1 to PCH so I get *16 on PCIE16X16_1 and PCIEX16_3.*
    Bottom line no matter how you slice it is if you want bootable raid on CPU Lanes it must be intel drives, if you want raid on PCH you can use whatever drives you want. Search VROC X299 section, sit back grab your favorite libation and read a bit. We pounded this hard at product launch Q4 2017.*
    The reference to Optane in the last sentence is optane Memory sticks. *Refer to the section in A X299 manual VROC for info about raid on CPU lanes.*
    Intel isn’t about to allow the same functions on consumer or prosumer boards that are available to enterprise solutions that makes them 10 times more per machine. *If they did that we wouldn’t be having this conversation as enterprise customers would have already depleted all stock of motherboards if they can do the same at a fraction of the cost.*
    By all means feel free to try it. Maybe you can outsmart Intel and share with the rest of us. I’m not optimistic on any such endeavor though.
  9. #9
    Deltaphi PC Specs
    MonitorASUS PG279Q
    Mouse Corsair M65
    Deltaphi's Avatar
    Jan 2019
    5
    Thanks a million!
    So I might as well use single Samsung 970 Pros than RAID 0 for Windows OS and Apps+Games separately.
    Thanks for all your trouble to provide such detailed information, it was an eye opener.
    All the best,
    Dimitris
  10. #10
    ProcessorI9 9940X
    OS Win10 Pro 1809
    Nov 2013
    144
    3,857
    That would be my advice. If I were you would leave a single on CPU lanes for OS and the other on PCH for large app installs.*
Tags for this Thread
