Results 1 to 8 of 8
    ROG Member Array
    Jan 2019
    5
    LiveDash issue with Ryujin 240
    Hi, I just recently got a Ryujin 240 and when I wake the computer up from sleep it resets to asus logo and lights go to rainbow instead of static.
    I have reinstalled it and unplugged and replugged it into the motherboard.
    I also wonder if it's possible to go full white on the LED colour?
    ROG Member Array
    Jan 2019
    5
    Also only the stock gifs work, I can add jpegs but not gifs eventhough I follow the 160x128 and max 1mb requirements.
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardCrosshair VIII Dark Hero
    Processor5900X 4.6ghz All core 1.3V, 5ghz single DOC
    Memory (part number)Gskill NEO 3600 CAS 14 32GB (4x8)
    Graphics Card #1ROG Strix RTX 3080
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 980 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 980 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks 500A Mesh
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur Virtuoso
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    999
    Quote Originally Posted by jesper.se View Post
    Have you updated to the latest firmware 1.00.05 with the update tool?
    1.00.05 improves gif capapbilities
    Also be sure to use the latest LiveDash 1.04.12
    And to control pump and fan curves use AI Suite 3.00.28
    All can be found here:
    https://www.asus.com/us/Cooling/ROG-...Desk_Download/
    Side note. I use Live Dash only to set what items I want to see on the panel and then rarely start the program again. I control the RGB on the Ryujin with the latest Aura and settings do seem to hold coming from sleep. On occasion, coming from sleep, my panel does revert to the ROG gif. Starting Live Dash or a reboot corrects it. But it does not seem to be a frequent issue.
    Please confirm if your software and firmware is up to date.
    ROG Member Array
    Jan 2019
    5
    I have an MSI board though, so I don't have a need for AI Suite, I just use the livedash software.
    As for Livedash I've tried with all 3 releases.
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    999
    Well, that’s your problem then.
    Answer is here: **https://rog.asus.com/forum/showthrea...us-Motherboard
    ROG Member Array
    Jan 2019
    5
    I've read that post but it's about the hardware monitor, I just want my own gif to play on the screen, I don't really care about seeing my temps there, can see them in windows.
  7. #7
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    80
    999
    Did you update the AIO firmware as well?
  8. #8
    ROG Member Array
    Jan 2019
    5
    Yes, in 1.00.04 it tries to play the gif but doesn't suceed (screen gets all glitchy) in 1.00.05 I get a warning saying "Apply Error. Please retry again."
Tags for this Thread
