Results 1 to 6 of 6
    ROG Guru: Yellow Belt Array Marko911 PC Specs
    Marko911 PC Specs
    MotherboardAsus Rampage extreme VI
    Processori9 7900x @4,7Ghz cores at from 7x1,20v-3x1,21v
    Memory (part number)G.skill 32GB 3200MHZ CL14 DDR4 quad kit
    Graphics Card #1Aorus 1080ti extreme edition @2032Mhz/12000Mhz
    MonitorAsus something IPS,144Hz ,Freesync
    Storage #1m.2 Samsung EVO 960 1TB
    Storage #2m.2 Samsung EVO 960 500GB
    CPU CoolerEKWB monoblock
    CaseThermaltake view 71 TG
    Power SupplyCorsair RM1000i
    Keyboard rappo wireless keyboard and mouse
    Headset Logitech G933
    OS win 10 pro/64bit
    Accessory #1 HL GTS 360mm/push only
    Accessory #2 HL SR2 360mm push/pull
    Accessory #3 HL SR2 420mm push/pull
    Marko911's Avatar
    Dec 2017
    141
    Question HYPER M.2 X16 CARD V2 vs V1?What's the difference?
    Hi there,As I mentioned above,what is the main difference between these two models? currently I can only find V1 model in stock in HU.
    Thanks for the help!
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,857
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    262
    Asus turned the drive sockets around for better drive cooling and increased the power available to the drives.
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    So,is this card V1 reliable to install and run 4x 2T 970 EVO Samsung or not?
    G75rog PC Specs
    ProcessorI9-7900X
    Sound CardStock
    Jan 2013
    13
    262
    I have been running 4 2TB 960 Pro's in mine for months with no problem. It currently has a booting 1TB 960 Pro, 1TB 970 Pro, and 2 2TB 970 Evo's in it.
    Marko911 PC Specs
    OS win 10 pro/64bit
    Marko911's Avatar
    Dec 2017
    141
    Quote Originally Posted by G75rog View Post
    thats great news!so V1 it is.
Tags for this Thread
