Results 1 to 8 of 8
    ROG Member Array
    Oct 2013
    13
    ROG Rampage IV Extreme USB 3.0 Issue
    I am still using my ROG Rampage IV Extreme and am "extremely" happy with it
    I have come across an issue that I am unable to resolve on my own. The I/O connector at the back of the mother board has four USB 3.0 connectors labeled as 1 through 4. USB 3.0 connectors 1 & 2 work fine. I am having issues with connectors 3 & 4. When I connect any USB device to either USB 3 or 4 nothing is detected by the OS (Windows 10). The connectors are "alive" in that, if I put a thumb drive into either 3 or 4, the drive indicator light turns on but, still, the devices are not detected.
    I have looked through the bios setup screens and all ports are enabled except for USB 13 which says the bios says is not in use.
    Any idea why USB 3.0 #3 and #4 are not working or otherwise inactive? Could plugging in USB connectors to other motherboard connectors have disabled these two connectors?
    Any thoughts would be much appreciated!
    Joe
    ROG Enthusiast Array vennacher PC Specs
    vennacher PC Specs
    MotherboardRampage IV Black Edition
    ProcessorCore i7 3970x
    Memory (part number)Corsair Vengeance 64GB CMZ64GX3M8A1866C9
    Graphics Card #1EVGA GTX690
    Sound CardSoundBlaster X-Fi Titanium
    MonitorHP LP3065
    CPU CoolerCorsair H100i v2
    CaseSilverStone TJ07
    Power SupplyCorsair AX1200i
    OS Windows 10
    Jan 2013
    67
    A couple things to check. Unplug all your USB devices. First, in your BIOS make sure all 3 USB3.0 hubs are enabled. The first two each power 2 of your external USB3 ports and the third powers the internal USB3 port. Reboot.
    Second, open device manager and for view select "hidden devices" . Open USB serial bus controller and storage volumes sections. You'll likely see some entries with a solid icon and others with a shadowed icon. Delete all the shadowed icons. Next under the serial bus controller section delete all ASMedia USB3.0 extensible host controller entries and USB Root HUB (USB 3.0) entries that have a solid icon. Reboot.
    Upon rebooting windows will detect the USB ports you delete and reinstall the driver.
    MB : Rampage IV BE. - Bios 0801
    CPU : i7 3970x @ 4500 MHz, Offset +0.030v, Regular LLC, Fixed Frequency 750, C1E Enabled, C3/C6/C7 Disabled
    CPU VCCSA: Manual 1.150v, Regular LLC, Fixed Frequency 500
    RAM : Corsair Vengeance @ 1866 MHz - 64GB
    Disks : Raid0 2x Intel 520 480GB; 2x Seagate 2TB
    GFX : EVGA GTX690
    Audio : Creative X-FI Titanium HD
    PSU : Corsair AX1200i
    Optic BD\DVD : Lite-On Blu-Ray; Samsung DVDRW
    Cooler\Case : Corsair H100i v2 2; Silverstone TJ07
    OS : Win10 Pro 64
    ROG Member Array
    Oct 2013
    13
    Quote Originally Posted by vennacher View Post
    Thanks for the thoughts. I will give that a try later on in the evening and let you know what I find.
    Best Regards!
    ROG Member Array
    Oct 2013
    13
    I know this is a very, VERY old thread but I was never able to resolve the issue with USB3.0 ports 3&4 not working. Both controllers are enabled in bios and there's not much else I can think of. In device manager I have three (3) instances of ASMedia USB Root Hub, three (3) instances of ASMedia USB3.0 eXensible Host Controller,, the two (2) Intel C600/X79 USB2 Enhanced Host Controllers, etc., etc. all apparently working properly.
    I guess it's just possible that the hardware driving those two ports is bad.
    New ROGer Array
    Feb 2021
    3
    Have the same problem
    Hi I have the same problem, if someone has succeded in resolving this issue please send me a MP I will receive a notif. Thanks a lot
    Nate152 PC Specs
    MotherboardROG Strix Z690-F Gaming WiFi
    Processori7-12700KF
    Memory (part number)Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40BBK2-16)
    Graphics Card #1ROG Strix 3090 Ti LC OC
    Sound CardROG SupremeFX
    MonitorHP ZR30w
    Storage #1Seagate Firecuda 530 1TB
    CPU CoolerEK Quantum Velocity2
    CaseThermaltake Tower 900
    Power SupplyEVGA Supernova 1600 T2
    Keyboard ROG Falchion NX / Strix Flare II
    Mouse ROG Chakram X/Chakram Core/Spatha X
    Headset ROG Delta S Animate
    Mouse Pad Steelseries Prism XL + ROG Scabbard II
    OS Windows 11 Home
    Accessory #1 2x Swiftech Maelstrom X300 D5 V2
    Accessory #2 2x Hardware Labs SR2 560 MP radiators
    Accessory #3 Lamptron FC-5 V3 fan controller
    Nate152's Avatar
    Feb 2013
    400
    17,679
    Hello,
    Does device manager show anything abnormal?
  7. #7
    New ROGer Array
    Feb 2021
    3
    Quote Originally Posted by Nate152 View Post
    Hello,
    Hi Nate,
    Thanks for your answer
    Here is my original post that could make you understand better the situation -> https://answers.microsoft.com/en-us/...a-f5e5a590c377
    YOu can read only my first message with the images which show that the hardware device is considered as not plugged when I reboot or go to sleep mode and awake the sytem...
    Since then I did sme changes in the bios but it did not solve my problem ( I activated the ErP ready and the ASMedia 3.0 battery charging->
  8. #8
    New ROGer Array
    Feb 2021
    3
    Nobody here for helping ?
