Results 1 to 5 of 5
    New ROGer Array
    Nov 2018
    31
    What is safe VCCIO and system agent voltages for daily high memory overclocks?
    I have my ddr4 memory looking to be stable at 4133mhz 16 16 36 2T 1.49v however when I checked what auto voltage had set VCCIO and system agent to was 1.35v and 1.4v. This seems very very high yes?
    Am I right in saying under 1.3v for daily use on both would be fine? Or do they need to be even lower?
    ROG Guru: Yellow Belt Array x-rated PC Specs
    x-rated PC Specs
    MotherboardAsus ROG Maximus XI Formula - Intel Z390
    ProcessorIntel Core i9-9900K @ 5 GHz
    Memory (part number)G.Skill Trident Z F4-3600C16D-16GTZR - 4x 8 GB, 4,3 GHz, 17-18-18-38
    Graphics Card #1Nvidia GeForce RTX 2080 Ti FE - 2,1/15,6 GHz
    Sound CardCreative Sound Blaster X7
    MonitorDell UP2715K - 5120x2880, AH-IPS, 10bit
    Storage #1Samsung 960 Pro - 1 TB, 3,5/2,1 GB/s
    Storage #2WD Red WD40EFRX - 4 TB, 64 MB, 5400 RPM
    CaseFractal Design Define R6 Blackout TG
    Power SupplyCorsair HX1000i - 1 KW, 83 A, 80Plus Platinum
    Keyboard Logitech G810 Orion Spectrum
    Mouse Logitech G403 Prodigy Wired
    Headset Sennheiser HD 660 S
    Mouse Pad Razer Manticor
    OS Windows 10 Pro
    Network RouterHuawei HG8245H @ 1 Gb/s FTTH GPON
    Accessory #1 EKWB Velocity + Vector
    Accessory #2 EKWB XRES 140 Revo D5 PWM + 2x CoolStream XE 360
    Accessory #3 6x Noiseblocker NB-eLoop Fan B12-PS
    x-rated's Avatar
    Aug 2015
    11
    192
    i dont think asus would push something dangerous through its auto settings although in many cases such high values are not necessary
    i have set both at 1,3V in bios for 4266 MHz
    New ROGer Array
    Nov 2018
    31
    Quote Originally Posted by x-rated View Post
    That 1 way to look at it I guess. Ok thanks. And you are comfortable running that daily on both?
    x-rated PC Specs
    OS Windows 10 Pro
    x-rated's Avatar
    Aug 2015
    11
    192
    when i was trying lowering those values, even though it seemd stable for some time, after long time heavy load some instability occured so i had to rise them to 1,3V and now everything works great 24/7 so im comfortable with that
    New ROGer Array wonderin PC Specs
    wonderin PC Specs
    MotherboardX99 Strix Gaming
    ProcessorIntel i7 6850k
    Memory (part number)HX430C15PB3K2/32
    Graphics Card #1Strix 1080 Ti OC
    MonitorDell S2417DG @165
    Storage #1Samsung Evo 960 m.2
    CPU CoolerNZXT Kraken x62
    CaseCorsair 780
    Power SupplySeaSonic Prime 750W Titanium
    Keyboard Razer Blackwidow Chroma 2
    Mouse Razer Death Adder Elite
    Headset HyperX Cloud
    Mouse Pad Razer Gigantus
    OS Windows 10
    wonderin's Avatar
    Dec 2018
    48
    never NEVER trust the auto settings
