Results 1 to 9 of 9
    ROG Member Array
    Jan 2019
    13
    Ringing sound coming from my laptop (GL704GM)
    Hello. Some time ago, I went on this forum and asked about a weird buzzing noise that came from the laptop. It turns out that the noise in question was just coil whine. Although that problem is fixed, I just started hearing a new sound, coming from the right part of my keyboard, near the right fan. I found someone else on youtube having a very similar sound with their asus laptop. I tried to look at the comments but the answers are a bit vague. My computer makes a very similar sound, but it isn't as loud.
    https://www.youtube.com/watch?v=K9xAZAY1KvE
    Is the sound a normal occurence for asus laptops just like coil whining?
    Thanks in advance.
    ROG Member Array
    Jan 2016
    8
    Hi, I just purchased this same laptop yesterday and I'm noticing a weird intermittent buzzing noise at idle, it's not that loud but loud enough to be a nuisance. How did you fix the coil whine?
    I have not noticed any other noises yet but that buzzing noise is bugging me.
    Thanks
    ROG Enthusiast Array TopOkay's Avatar
    Dec 2018
    26
    Quote Originally Posted by Franck1997 View Post
    Thanks in advance.
    To me, seems a normal hdd noise. But what are you doing? When is not use it go on sleep.
    Quote Originally Posted by steve888 View Post
    Thanks
    Check this:
    https://rog.asus.com/forum/showthrea...ge4#post749830
    ROG Member Array
    Jan 2019
    13
    I can hear the sound when the computer is idle. When I want to play a game, I switch the computer to a balanced mode. When a game runs, the fans are so loud that I can't hear anything. However, when I don't play any games, I switch the computer to a silent mode, which reduces the power used by the computer. I tweaked it a bit so I couldn't hear the coil whining. But, as the thread's title says, I started hearing the ringing sound just recently after booting the laptop.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,669
    That's just the sound of a drive head seeking. Normal and expected.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Dec 2018
    26
    So strange... have you checked if your hdd is seeking while the noise going on?
  7. #7
    ROG Member Array
    Jan 2019
    13
    Alright, so for some unknown reasons, the noise is gone, for now. Now, the only way for me to hear anything is if I literally put my face right next to the keyboard. I don't really know what happened. I'll post here again if something else happens.
  8. #8
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    309
    7,669
    Your hard drive may thrash more if Windows is processing updates or indexing files. Once it completes whatever task is consuming the drive it should go quiet. So don't be surprised if the sound comes back.
  9. #9
    ROG Member Array
    Jan 2019
    13
    Quote Originally Posted by xeromist View Post
    I think that makes sense. I just installed a game on steam just now and the sound suddenly returned. However, when the installation was over, the sound ceased as well.
