Results 1 to 5 of 5
    ROG Member Array
    Mar 2017
    6
    GX501 RMA advice
    Heyup guys,
    Can anyone shed some light on me RMA'ing my GX501. The graphics card has a Microsoft Code 43 error and the panel shows artifacts so I think it's dead. The thing is though... I have swapped out the SSD for a 970 Evo and I'm sure the sm961 had a little sticker on it where the screw holds it in place. Is this a warranty void sticker?
    Thanks for any replies. 😥😥
    ROG Guru: Yellow Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)Lenovo
    MotherboardROG Maximus IX Extreme, BIOS 0201
    ProcessorI7-7700K
    Memory (part number)G-Skill F4-3600C17Q-16GVK
    Graphics Card #1ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #2ROG GTX 980 MATRIX-GTX980-P-4GD5 Bykski Water N-AS98ROG-X Full Cover
    Graphics Card #3GPU Tweak II 2.0.3.1 works, no GPU volt monitor since Version 2.8.3.0, shows in LN2 mode only
    MonitorSAMSUNG S22D300HY (2 ea)
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK Kit L360
    CaseINWIN 707, Corsair ML140 (4 each), Corsair ML120 (4 each)
    Power SupplyThermalTake Toughpower 1200W
    Keyboard Cerberus
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Win 10 Pro 1903
    Network RouterGeneric
    Accessory #1 ASUS Fan Extension Card
    Accessory #2 ASUS Blu-Ray Drive (BW-16D1HT)
    Accessory #3 ROG 10GB Express
    Jan 2016
    134
    some light
    RMA the GX501 in the condition that you brought it, because there is no guarantee that you will receive the item you RMA’ed. And then you will be howling about where is my 970 Evo?
    Did ASUS sell it to you with a 970 Evo?
    Try a RMA with what you purchased and you will receive one of two replies from ASUS, because of warranty sticker depending on your abode. Yes or No!
    EZ-PEE-Z!
    ROG Member Array
    Mar 2017
    6
    Can't do that. The other ssd is in another machine I don't have now. I'll specify I've changed it. Here's hoping
    pndiode PC Specs
    ProcessorI7-7700K
    Keyboard Cerberus
    Mouse Pad Generic
    OS Win 10 Pro 1903
    Jan 2016
    134
    Can't do that
    Otay!
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,414
    Quote Originally Posted by BaggyBizzle View Post
    If it was me I would consider throwing a cheap used drive in there, but up to you.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
