Results 1 to 4 of 4
    ROG Enthusiast Array BJBBJB PC Specs
    BJBBJB PC Specs
    MotherboardMaximus VIII Hero
    Memory (part number)G.Skill F4-2666C15Q-32GRR
    Graphics Card #1GTX560
    Storage #1Samsung Pro 950 SSD
    Storage #2Multiple Seagate Barracuda Drives
    CaseAntec P182
    Power SupplyEnermax Modu 82
    Mouse Logitech MX Master Wireless
    Headset/Speakers Logitech 5.1
    OS Windows 10
    Oct 2015
    63
    Ai Suite 3-Fan Qpert upgrade - Where are my custom profiles?
    Before I upgraded AiSuite 3 I saved my current custom fan profile as the profile I was currently running and saw ALL of my other saved tweaks I tediously setup when I did my build when I saved it. Several....
    After my the update of AiSuite 3, I see NONE of them! Just the standard ones.
    I saved whatever profile it was running just in case it was my last default profile. But why did it blow away all of my profiles?
    Do they exist somewhere?
    It does not even look like it knows which fan is where anymore. What a pain....
    I hope they are out there somewhere. What kind of upgrade blows away your settings?
    LOL....this is why I don't like to upgrade..
    BJBBJB
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,125
    Mine all got deleted at some point in the past too. Like you, I had no idea why. In the end I wound up re-creating them since I never found them. This is where someone can say honestly, I feel your pain. I haven't lost them a 2nd time (knock on wood).
    Davemon50
    BJBBJB PC Specs
    CaseAntec P182
    OS Windows 10
    Oct 2015
    63
    Quote Originally Posted by davemon50 View Post
    davemon50,
    Thanks. I think I found the file. Under Program Files(x86)/Asus/AsusFanControl Service there are two folders. 1.06.28 and 2.00.33.
    There is an XML file in each called "FanStore" and some settings appear to be stored there but don't see my custom names. I am temped to copy the old one over but I also know there were that funky fan spinup and spindown thing it did. And if buried in the file are settings that fix that, I don't want to bring them back.
    I guess I will just re-set them up also but wanted to share that info. I don't know even how the program inter-reacts with that file to just use it. I would have thought they would have designed an upgrade to save those configurations?
    I know some swear by using the bios settings for fan control but if I recall correctly there were some lower RPM's you could not get there. Also, I thought it would be smart to have my settings saved in FanXpert so when I updated the bios, I could just reload them!
    Thanks,
    BJBBJB
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,125
    Ah, thanks for the location. Not sure I every probed into that folder. But XML files might change from version to version anyway, so it's probably good you recreated the profiles.
    Davemon50
