In software under controllers you have to add everything manually. Add contoller, what channel its controlling then you can change source to anything you want. the Aquero software is certainly not user friendly and a pretty steep learning curve. There are several tutorials I found that helped me figure it out. If all else fails they have a forum to ask quesitons that the developers closely monitor. You can even create a custom monitoring panel, this sits on the top right of my desktop. The monitoring panel does take a lot of time, this took me the better part of a day.
You can also add AIDA64 as a source for monitoring.
Takes some time to learn but once you have it down, nothing else compares or even comes close.
