Top right shows 2 notifications
ThrashZone
Been that way for a long time I have nothing in inbox so what's going on with the 2 symbol for inbox messages 😄
[SIGPIC][/SIGPIC]
6 REPLIES 6
ThrashZone
They're gone now who did that thanks 🙂
Dang even my sig showed up !!
[SIGPIC][/SIGPIC]
Zammin
I have the same issue, for ages my icon in the top right says I have 2 notifications and when I click on it my inbox says I have 2 messages, however when I go to my inbox there are no messages. It's so weird.
Check your friend invites, they also show up as notifications.
Davemon50
Same here: notifications for two messages in inbox but nothing there. No friend invites either. Been that way forever.
davemon50
Level 11
Check also Settings & Functions > Settings. If anything shows up in your reputation, it also shows as a notification.
Davemon50
ThrashZone
All I did is go to inbox and used empty folder same I've done many times in the past only difference is it actually worked yesterday 🙂
[SIGPIC][/SIGPIC]
