Results 1 to 6 of 6
    ROG Enthusiast Array Basspig PC Specs
    Basspig PC Specs
    Laptop (Model)GL-753VE-IS74
    MotherboardZ390-A
    Processori7-9700K
    Graphics Card #1GTX1060
    MonitorHP LP3065
    Storage #1Samsung 970EVO M.2 NVMe 250GB
    Storage #2Samsung 2TB SSD SATA
    CPU CoolerNoctua
    Power SupplySeasonic 850FX
    OS Windows 10 Pro
    Network RouterLinksys WRT3200ACM
    Basspig's Avatar
    Dec 2018
    32
    Question Converting to UEFI Mode Safely? Z390-A Motherboard
    This my first Windows 10 system, and I was unfamiliar with UEFI so when I installed Windows 10 Pro, it automatically setup my drive as MBR.
    I learned later on that I can convert the drive to GPT with Microsoft's MBR2GPT program.
    The thing is, I want to make sure I configure the BIOS correctly before booting into that drive after conversion.
    The plan is to convert the drive, either from within a CMD shell, or with a recovery disc's CMD shell, then enter BIOS setup and do the changes needed.
    What are the areas of BIOS config, starting with the top menu, that I need to set up for UEFI before I attempt to boot the converted GPT drive?
    I'm hoping to get it right the first time so I don't end up with an unbootable system.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    What drive are you using?
    Jun 2013
    42
    I remember when doing mbr2gpt, I did that first, then restarted, went into BIOS and my Asus board had already recognized it as UEFI Windows boot manager, using a 950 pro NVME in the m.2 slot
    This was a x99 strix.
    Basspig PC Specs
    MotherboardZ390-A
    Processori7-9700K
    MonitorHP LP3065
    CPU CoolerNoctua
    OS Windows 10 Pro
    Basspig's Avatar
    Dec 2018
    32
    Samsung 970 EVO NVMe M.2 drive plugged into an M.2 socket on motherboard.
    Reason I ask about all this is because I am setting up WIndows 10 on another system and switching back between a Windows 7 non UEFI drive and a Windows 10 UEFI drive proved problematic with much configuration changes in the BIOS necessary to get the system to actually boot.
    Also, did you use the AllowFullOS switch to convert from within the running environment?
    My Z390-A also switched to internal graphics when something in the drive menu wasn't set to Legacy mode, and I spent hours last month trying to figure out why I had no video display after updating the BIOS. Two things had happened: the drive type defaulted to whatever is the non-legacy mode (so it couldn't find a boot drive, and when that happens, it forces the the internal video and ignores the PCI video card. I eventually had the idea to try plugging in a displayport monitor on the motherboard video and saw the boot process there. Spent an hour trying to figure out why it would not let me select PCI graphics. Then I remembered that the disk feature used to be set to Legacy (something which bothered me, because the NVMe drive is pretty new tech--I didn't realize Legacy meant MBR format) and I went and set that to Legacy and then the board would allow PCI graphics again.
    I'm just concerned that I don't get into that mess again during this conversion. I spent a month tweaking and working out the quirks in Windows 10 Pro, getting my legacy scanners, tablet and MIDI stuff all working and configured.. 100+ hours of troubleshooting, research, driver hunting, hacking and modifying config files to get everything working. Would have to lose it all!
    Basspig PC Specs
    MotherboardZ390-A
    Processori7-9700K
    MonitorHP LP3065
    CPU CoolerNoctua
    OS Windows 10 Pro
    Basspig's Avatar
    Dec 2018
    32
    I plan to do this over the weekend.
    Is there any danger to using the AllowFullOS switch on the MBR2GPT command to effect the conversion from within the Windows environment, or should I boot from a recovery environment to do this?
    Regards,
    Mark
    "If it doesn't cause an earthquake, you need a bigger subwoofer."
    Basspig PC Specs
    MotherboardZ390-A
    Processori7-9700K
    MonitorHP LP3065
    CPU CoolerNoctua
    OS Windows 10 Pro
    Basspig's Avatar
    Dec 2018
    32
    I successfully converted my MBR boot disk (an M.2 NVMe drive) to GPT and booted into UEFI and turned off Legacy mode and verified proper Windows boot loader. Booted up into Windows 10. The odd thing is it doesn't turn on the monitor until I press a key, where I then see the log on screen.
    I was used to AutoAdminLogon in Windows 7, so I just used netplwiz and set my account to not require PW to log in.
    Not my system boots in 10 seconds to the desktop from hitting the power button. I think I can shave off 2 more seconds by eliminating the delay of 2 seconds to display the boot prompt (now pointless in UEFI protected mode).
    There are probably other tricks to improve boot time. I know Linus Tech Tips got their system down to under 5 seconds boot by doing some extreme measures.
    Thankfully all my legacy hardware, such as slide scanner and MIDI interface still works.
    Regards,
    Mark
Tags for this Thread
