Results 1 to 4 of 4
    ROG Member Array
    Jan 2018
    5
    Rear USB 3.1 ports not working
    Help please!
    I can't seem to get my usb 3.1 gen 2 A (red one) and Type C to work. Power is coming out of them (I plug in a device and lights come on) .
    Latest Bios and chip set are installed.
    XHCI hand-off is disabled ( I also tried enabled but didn't work)
    When I tried to update to the latest USB driver from Asus I got an error.
    ROG Member Array
    Jan 2018
    5
    Is there no one who can help?
    No reply's? Are my usb ports doomed?
    Or am I just an idiot and it's a simple fix that should be obvious?
    Any one?
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    12
    1,330
    Quote Originally Posted by beefcake666 View Post
    Any one?
    I detect these on my CodeXI when i connect my BRIO WEB CAM..ODD The webcam driver install a ASMEDIA USB 3.0/3.1 eXtensible Host Controler. That disable 3 usb3.0 back usb2.0 Please Check BIOS and Chipset if that make a change.
    I will work on a X399 today. I can check these also. But I will make a clean install in order to check if these is a issue or not. Be noted that I make a udate on theose Asmedia drivers direct on Device manager and deactivate those port complete.
    THere is a app. called USB Device Tree Viewer https://www.uwe-sieber.de/usbtreeview_e.html#download
    These will check what and is working or not. I find these myself 2 days ago.
    Learn, Play Enjoy!
    ROG Member Array
    Dec 2017
    14
    I recently got this problem, I returned to 1601 bios in hope it would resolve the problem but no luck.
