ROG Strix Fusion 700 USB port
g_rowell
Hi ASUS / MasterC@ASUS
so i bit the bullet and went out and purchased the ROG Strix Fusion 700 Standard store rules apply cannot inspect before you purchase because box is sealed etc
anyway get it home and open it go to plug in the ROG USB strait away notice the cable doesn't want to fit seems hard to get try another USB cable same again
so i have a closer look at the USB plug on the Headphones and it looks like during assembly something has moved an it's not in the correct position and please note this was only purchased today.
SERIAL NUMBER J7YHGEE01740
g_rowell
Update: Taken the Head phones back to Place of purchases and they have replaced them on the spot now on to the next issue
