02-17-2012 08:54 AM - last edited on 03-06-2024 03:28 AM by ROGBot
02-17-2012 12:07 PM
02-19-2012 11:58 AM
BrodyBoy wrote:
It's been completely gone in Device Manager for a month? Or is the "disappearing" intermittent?
I would suggest you go into the BIOS and make sure the optical drive has not become locked somehow.
02-19-2012 12:11 PM
02-19-2012 12:52 PM
02-19-2012 12:59 PM
02-19-2012 03:26 PM
02-19-2012 03:48 PM
02-24-2012 05:20 AM
fuzon1337 wrote:
You could try to take out the ODD and remove it and then reconnect it. To see if that helps.
This is simple and not difficult to do, so here is a link with pictures (scroll down on that link until you see this text: "1. Remove 1 screw on the ODD and take the ODD away").
03-05-2015 04:21 AM
