ROG Ryujin 240 Fan Curve
Thrawn0502
Hi folks, I have the AIO installed on my I7 8700k today. I have followed every step everything connected correctly and the firmware updated to 1.05. Unfortunately, all fans in the AI ​​Suit 3 are always at 100%. Is not there a fan curve from Asus?
Update:
After hours of searching and testing, I give up. This AIO makes something visually but for this price is very poor. The volume under load is unbearable, especially the NVRAM fan is hell. The Noctua fans can be heard clearly from 50%. I am really an Asus fanboy but I can not recommend this product especially in the price range. I really do not want to comment on the really bad fan control at this point!
greetz
Thrawn
mdzcpa
Level 12
Update:
greetz
Thrawn
Do you see the individual Pump and Fan curves appearing under Fan Expert in AI Suite III?
When they do not appear, or they appear but curve adjustments do not work, there are two ways to cure.
Uninstall AIS and re-install AI Suite version 3.00.28 https://dlcdnets.asus.com/pub/ASUS/mb/Utility/AI_Suite_III_3.00.28.zip?_ga=2.84053721.1323939482.154...
Run the Fan Tuning in Fan Expert.
Gofran
he i had this issue also put aio header in cha1 fan one next to it that should work
You can also connect the pump header to the CPU_Fan.
