Results 1 to 5 of 5
02-10-2019 12:00 PM #1
- Join Date
- Feb 2019
- Reputation
- 10
- Posts
- 2
Ryzen 7 2700x / x470-f high CPU temp issue
Hi there.
I just built a new system based on Ryzen 7 2700x and Asus x470-f. My issue is when all settings of my MoBo is left on "Auto" the CPU Vcore goes crazy high (1.4 - 1.5V) even with simple tasks on win10. I can manually set my Vcore(from BIOS) to 1.35V and its stable and the temps are 40C at idle and 52-58C in games or high load software.
My question is , is there an option to leave the board Ai settings at auto but make sure the voltage doesnt go too high, because in auto mode if the vcore goes beyond 1.4V the CPU temps become 67-69C and thats with a Cooler Master Masterliquid 240L AiO.
I don't like to OC anything so all I want is a cool stable stock valued system. I hope someone can help me or guide me through the best settings and tweaking for my ryzen 2700x and x470-f motherboard.
My system is ;
Ryzen 7 2700x
Asus ROG x470-f
Corsair Vengeance LPX 3200mhz DDR4 RAM
Gigabyte 1080 ti 11G gaming edition.
Cooler Master ML 240 RGB AiO
Thermaltake toughpower 850w PSU
Thanks.
Ps. Yes my BIOS is up to date and the high CPU temps arent related to thermal paste (using high quality thin layer mastergel) and yes the AiO pump is working great
02-10-2019 03:34 PM #2
- Join Date
- Jun 2018
- Reputation
- 10
- Posts
- 57
02-10-2019 03:42 PM #3
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
My Threadripper was doing the same thing...I have used a negative offset to reign in the voltage... currently run -0.09375v and it hasn't affected idle stability...
Maybe try a negative offset there start low and slowly increase it
02-10-2019 07:30 PM #4
- Join Date
- Feb 2019
- Reputation
- 10
- Posts
- 2
fine tuning.
Thanks.
I'll try the negative offset experiment and see how it goes. Just to figure out the concept, when I do a negative offset will that also lower the lowest voltage the cpu goes?
for e.g in Ai auto mode the motherboard sets the voltage between 0.8V and then to 1.4 or 1.5V ; yes it will reduce the max voltage but if it reduces the lowest point the cpu might cause trouble or the pc might freeze.
Anyway I'll try n see
02-11-2019 07:28 AM #5
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
Yes, that's why I mentioned idle stability...since it does indeed chop voltage off throughout the vid range...just have to experiment a bit I guess
You can see difference between vid and offset voltage...max is now 1.4v for the one or two core AFR...and idle is 0.762 instead of 0.85 for me...
I know I can offset more for the top end...but haven't pushed it for fear of destabilising the bottom end...just gone for a happy compromise area
