Results 1 to 9 of 9
    ROG Enthusiast Array
    Nov 2018
    11
    54
    2080 how much stress is enough
    I am overclocking my Strix 2080 and wondering how much stress testing is enough? Also, what software is best for this?
    I am currently*using 3DMark Time Spy Extreme stress test. I notice that one setting passes this 2 times, then I get a crash on the 3rd stress test. So I am a bit lost, probably this means that the setting is not stable. So how much is enough?
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,578
    The 3D mark software is fine for testing...try a few benchmarks at different settings...
    Then check real world with your games/applications etc.
    The higher you go the more chance of instability...especially with memory OCs which are next to useless on GPU for gaming or 24/7 OCs...
    How much is enough?...is a difficult question and impossible to answer really...depends what you are doing. Just back off the OC a bit for daily use...forget other people's numbers and realise that the last few MHz that give you instability won't be giving you much performance anyway. So, for your current situation...I'd call that unstable and settle for a bit less instead of convincing myself that 2 runs is stable if you know what I mean..
    Nov 2018
    11
    54
    My problem is that when playing new games like Apex, I cannot know if a crash is related to a game bug, or my overclock. How do you guys test for stability? How many stress tests do you run, if its 3DMark? Should I do 3 and call it stable?
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    127
    1,853
    Beyond testing in the real world, Time Spy Stress Test loops the routine 20 times. If you're able to pass this without locking up, then it's a good indication of stability.
    If Apex Legends is crashing there should be a system event within event viewer. You can see if the display driver is crashing or not from within the system panel.
    Nov 2018
    11
    54
    Quote Originally Posted by Silent Scone@ASUS View Post
    What would be the recommended course of action if I run this stress test 2 times and the 3rd one crashes? Back down and try 3 times again :-/?
    Mar 2016
    127
    1,853
    Quote Originally Posted by Eclipt View Post
    Or back down until you're able to complete the stress test.
  7. #7
    Nov 2018
    11
    54
    Thanks for the Event Viewer tip, I will be keeping an eye on that! Maybe you would have some ideas why my OC Scanner does not work anymore ? It worked for 1 time and now it stops at 1%. Maybe something messed up and there is a way to "clean up"?
  8. #8
    Nov 2018
    11
    54
    Nevermind, this is solved by reinstalling drivers with "clean install" option and trying a previous version of GPU Tweak.
  9. #9
    Mar 2016
    127
    1,853
    There are a few outstanding issues with the latest version of the scanner, should be fixed shortly.
