Page 11 of 15 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 101 to 110 of 143
  1. #101
    ROG Guru: Orange Belt Array ninezerofive PC Specs
    Laptop (Model)Laptop ? Ewww
    MotherboardMaximus XI Apex
    Processori7-9700K @ 5.2
    Memory (part number)Trident Z Royal 4000 / 2x8GB @ C17
    Graphics Card #1ROG Strix 1070 OC
    Storage #1Corsair MP510 960 GB
    Storage #2Seagate 3TB
    CPU CoolerROG Ryuo 240
    CaseROG Helios
    Power SupplyROG THOR 850W
    Keyboard ROG Claymore
    Mouse ROG Pugio
    Headset ROG Cerberus
    Mouse Pad ROG Whetstone
    Accessory #1 ROG Terminal
    ninezerofive's Avatar
    Nov 2018
    18
    254
    Quote Originally Posted by SoftAddict View Post
    I actually went and checked our local online stores, they are still with the same price tag since I placed them in save for later. so the price drop didn't reach us yet.
    https://www.corsair.com/uk/en/Catego...SD-F960GBMP510
    Check their official store, they ship the items from factory, from Taiwan with DHL so it doesn't matter where you are located.
    Also if you are new to corsair, create the account, and wait for the confirmation e-mail, once you confirm they will give you 20% off next purchase.
    But I think the just noticed that people are abusing this system and switched it off. But maybe its just geo locked and you can try it from your location.
    Maybe it works.
    P.S. In your list there's EVO 1TB, but I don't know if you know.The EVO PLUS just dropped and at least in UK it's the same price as regular EVO but with better performance. You can check that out as well.
    https://uae.souq.com/ae-en/samsung-9...-2-46288890/i/
  2. #102
    ROG Guru: Green Belt Array panzlock PC Specs
    panzlock PC Specs
    Laptop (Model)ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99
    MotherboardASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming
    ProcessorIntel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700
    Memory (part number)8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16
    Graphics Card #1EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56
    Monitor32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ
    Storage #1Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2)
    Storage #2Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
    CPU CoolerDeepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire
    CaseAntec Sonata, Deepcool Dukase V1, Deepcool Dukase V3
    Power SupplyATX 650, EVGA SuperNOVA 850 P2 (X2)
    Keyboard Logitech K220, MSI Interceptor DS4200 (X2)
    Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus
    Headset/Speakers Logitech Z313, Logitech Z506 (X2)
    OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
    panzlock's Avatar
    Nov 2016
    54
    701
    Monitor is a bit small.
    RAM is a little slow. Ryzen likes faster RAM and your board should allow 3200 without issue. 2999 at least.
    Ideal Vega GPU would be the Sapphire Nitro+ or ASUS Strix because of the superior cooling solution. But the Sapphire Pulse is a decent card. Stay away from Gigabyte.
    I'd like to deploy my troops in her country.
  3. #103
    ROG Guru: White Belt Array
    Dec 2018
    86
    Quote Originally Posted by ninezerofive View Post
    Maybe it works.
    Thanks bro i'll order the plus.
    thanks for your tip
  4. #104
    Dec 2018
    86
    Quote Originally Posted by panzlock View Post
    it's okay I don't mind the monitor I checked it before I buy it I was aiming for 144hz but it's more expensive so I went for the 75hz it's a good TN monitor fits my needs for the time being.
    mmm, rams didn't arrive yet so I'll look for one with 3200 and ask you about it.
    the sapphire pulse is already paid and on the way, I've checked the reviews and yeah it's a decent card.
    I'll just check for rams now
  5. #105
    Dec 2018
    86
    Quote Originally Posted by Arne Saknussemm View Post
    Yep that's on the list and being a lower frequency should be plug and play...no problem
    thanks for your input, but I'm confused now you guys are advising me of the different point of views, what should I pick.
    This: https://uae.souq.com/ae-en/g-skill-t...-1153500064/u/
    or
    This: https://uae.souq.com/ae-en/ram-g-ski...44172/i/#specs
    it's the FINALLY everything is PICKED, RAM remaining...
  6. #106
    Dec 2018
    86
    I want to thank you alot mate i already ordered it " the Plus:"
  7. #107
    CaseROG Helios
    Mouse ROG Pugio
    Nov 2018
    18
    254
    Great choice brother, I've been looking at the Evo Plus myself lately, but then here in UK the Corsair prices dropped so I picked that one up instead. But truth to be told, I believe in Samsung quality more than in Corsair
  8. #108
    panzlock PC Specs
    panzlock's Avatar
    Nov 2016
    54
    701
    or
    What Arne is saying is that Ryzen platforms had issues with RAM modules operating at advertised frequencies of 3000 Mhz or higher. Meaning that if you purchase RAM with these speeds and it is not on the QVL list there is no guarantee it will run at these speeds. The MB you are purchasing supports speeds no higher than 3600 Mhz, btw. Out of the box everything runs at standard DDR4 2133 Mhz speed, anyway:
    X470-F GAMING specs: https://www.asus.com/ca-en/Motherboa...pecifications/
    That being said, Ryzen seems to work better with faster RAM (as per reviews), so I suggest you get the fastest possible module at the best possible price within the MB specifications. However, as Arne mentioned it's better to buy something with slightly lower speeds instead of something that won't run as intended. Save some money.
    Just one example, on my B350-F GAMING board people bought 3200 Mhz RAM but the D.O.C.P. allowed no more than 2933 Mhz. Anything higher and it destabilized.
    Ryzen is a great platform but it's still a little touchy, that's all.
    Let me know how that Sapphire Vega 56 Pulse performs. I want a comparison to my 56 Nitro+.
  9. #109
    panzlock PC Specs
    panzlock's Avatar
    Nov 2016
    54
    701
    Since you sacrificed so much in hz you should get a slightly larger IPS panel (27" or 32") at 60Hz. IPS is generally better image quality and you can find some up to 165Hz.
  10. #110
    Dec 2018
    86
    Yeah sure i'll do some benchmarks and post here when settled
Tags for this Thread
