Page 12 of 15 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 111 to 120 of 143
  1. #111
    ROG Guru: White Belt Array
    Dec 2018
    86
    Quote Originally Posted by panzlock View Post
    Since you sacrificed so much in hz you should get a slightly larger IPS panel (27" or 32") at 60Hz. IPS is generally better image quality and you can find some up to 165Hz.
    I reconsidered the monitor im returning the current one and getting this, paying extra for more quality:
    https://uae.souq.com/ae-en/asus-vg27...nc-26074263/i/
  2. #112
    Dec 2018
    86
    this is my rig at the end, 3 more items to go. My Question here, is these items ready to get built or do i need small parts or extra handlers or other components or this is enough to setup the build???
    CPU: https://uae.souq.com/ae-en/amd-ryzen...er-33211827/i/
    MB: https://uae.souq.com/ae-en/asus-rog-x407--f/s/?as=1
    SSD: https://uae.souq.com/ae-en/samsung-9...-4492800055/u/
    RAM: https://uae.souq.com/ae-en/g-skill-t...232/i/Monitor: https://uae.souq.com/ae-en/asus-led-...5h-22130004/i/
    Case: https://uae.souq.com/ae-en/cooler-ma...es-39663154/i/
    PSU: https://gear-up.me/psu-evga-supernov...lar-135mm.html
    GPU: SAPPHIRE PULSE RX VEGA 56 (2048) ACTIVE 2XH 2XDP
  3. #113
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,687
    Thermal paste and thermal paste remover
  4. #114
    Dec 2018
    86
    Quote Originally Posted by Arne Saknussemm View Post
    a friend of mine told me that the cooler and the cpu , there will be placed on them thermal paste
    should i get more ?
    or will it be provided with the items ?
  5. #115
    Dec 2018
    86
    Meaning do I have to order one as well ?
  6. #116
    Apr 2012
    505
    13,687
    The cooler should come with some paste yes...but that is a one time deal...if you need to remount the cooler etc.
    If you are building a PC you should have a few things about just in case you encounter problems
    The paste that comes with the cooler is also not the best quality...it also has a tendency to cement to the CPU making removing the cooler a pain...people have damaged CPU pins because the CPU pulled out stuck to the cooler....
    https://www.reddit.com/r/Amd/comment...on_the_2700xs/
  7. #117
    ROG Guru: Orange Belt Array ninezerofive PC Specs
    Laptop (Model)Laptop ? Ewww
    MotherboardMaximus XI Apex
    Processori7-9700K @ 5.2
    Memory (part number)Trident Z Royal 4000 / 2x8GB @ C17
    Graphics Card #1ROG Strix 1070 OC
    Storage #1Corsair MP510 960 GB
    Storage #2Seagate 3TB
    CPU CoolerROG Ryuo 240
    CaseROG Helios
    Power SupplyROG THOR 850W
    Keyboard ROG Claymore
    Mouse ROG Pugio
    Headset ROG Cerberus
    Mouse Pad ROG Whetstone
    Accessory #1 ROG Terminal
    ninezerofive's Avatar
    Nov 2018
    18
    260
    Happened to me once, AMD AM3+ with ARCTIC MX-4, came straight out stuck to the bottom of the cooler.
  8. #118
    Dec 2018
    86
    Read a good deal of this Reddit thread and comments, seems scary. but that will happen only if I want to replace the CPU right? or remount the cooler?
    What should I do to prevent this ? should I get a thermal paste when I first build it? if yes which brand has good quality?
    I think this is a good one, no idea yet : https://uae.souq.com/ae-en/arctic-mx...ms-23515420/i/
  9. #119
    CaseROG Helios
    Mouse ROG Pugio
    Nov 2018
    18
    260
    Yeah I can vouch for ARCTIC MX-4, no complaints. Have used it in several builds and now it cools my 9700K @ 5.2 and does a good job at it.
    However its almost empty and I will have to get a new one soon, and have heard that this one is top choice now - Thermal Grizzly Kryonaut.
  10. #120
    Apr 2012
    505
    13,687
    Best kit for removing/cleaning
    https://gear-up.me/arctic-clean-clea...-ml-87671.html
    same stuff better price
    https://gear-up.me/thermal-grease-ar...-4g-87594.html
    MX-4 will probably be better than what comes with the wraith
    Quote Originally Posted by ninezerofive View Post
    Heh...no problem if you are expecting it but I see people snapping pins when they aren't
Tags for this Thread
