Page 13 of 15 FirstFirst ... 3 11 12 13 14 15 LastLast
Results 121 to 130 of 143
  1. #121
    ROG Guru: White Belt Array
    Dec 2018
    86
    Quote Originally Posted by Arne Saknussemm View Post
    Best kit for removing/cleaning
    https://gear-up.me/arctic-clean-clea...-ml-87671.html
    same stuff better price
    https://gear-up.me/thermal-grease-ar...-4g-87594.html
    MX-4 will probably be better than what comes with the wraith
    Heh...no problem if you are expecting it but I see people snapping pins when they aren't
    Thanks mate !
  2. #122
    ROG Guru: Orange Belt Array JimmyH PC Specs
    JimmyH PC Specs
    MotherboardROG Strix Z370-E
    Processor8700K
    Memory (part number)CMK32GX4M4B3200C16
    Graphics Card #1ASUS STRIX GTX 1080
    MonitorBenq 27" x 2
    Storage #1Samsung 970 EVO
    CPU CoolerThermaltake Floe Ring 360
    CaseThermaltake View 71
    Power SupplyCorsair RM 850x
    Keyboard Strix
    Mouse ROG Pugio
    Headset Logitech933
    OS Windows 10 Pro
    JimmyH's Avatar
    Nov 2012
    20
    295
    Mate, I have used ASUS for a decade now and swear by them technology and efficiency wise. I was even into overclocking in my earlier years and they are a dream.
    AMD/INTEL is just a preference, ASUS excel at both. I love the fact that they have branched into cooling and PSU, hopefully, RAM is next on the cards.
    They are great with any RMA and technical support.
    If you are going for RGB side of things, I wouldn't really recommend them at present. For me it's their only downfall, and when I mean downfall, they just don't have their act together yet. This is my only negative.
    If you can squeeze it into your budget, I would go for an M2 SSD for your primary. You can partition it if necessary and have ample room for your operating system and your favourite game if that is your thing.
    If your budget is tight, 16 GB of RAM is sufficient for nearly every game out there. You would be surprised at how much RAM you actually use. And unless your planning on overclocking, you could save a few dollars with just a plain 8700.
    Just my opinion.
    CPU i7 8700K: MB: ROG Strix Z370-E Corsair Vengeance 3000 (4x8GB) : GTX-1080: Samsung 970 EVO, 2 x Kingston Hyper X
    500GB Velocerapter, PSU Corsair RM 850x
    Case Thermaltake View 71: Cooling Thermaltake Floe Riing 360 mm
  3. #123
    Dec 2018
    86
    Unhappy
    I NEED HELP GUYS !
    I got all the items and building the rig since morning,
    installed the CPU, ram , ssd ,
    now im aligning and placing the mobo in the case for some reason the a.o shield is built into the motherboard but i can't align it to the chasis. it's getting me really frustrated. it's either doesn't fit or i can't get it right.
    the mb : Asus x470-f gaming with cooler master h500p mesh white
    Please help!!
  4. #124
    ROG Guru: Orange Belt Array ninezerofive PC Specs
    Laptop (Model)Laptop ? Ewww
    MotherboardMaximus XI Apex
    Processori7-9700K @ 5.2
    Memory (part number)Trident Z Royal 4000 / 2x8GB @ C17
    Graphics Card #1ROG Strix 1070 OC
    Storage #1Corsair MP510 960 GB
    Storage #2Seagate 3TB
    CPU CoolerROG Ryuo 240
    CaseROG Helios
    Power SupplyROG THOR 850W
    Keyboard ROG Claymore
    Mouse ROG Pugio
    Headset ROG Cerberus
    Mouse Pad ROG Whetstone
    Accessory #1 ROG Terminal
    ninezerofive's Avatar
    Nov 2018
    18
    260
    Quote Originally Posted by SoftAddict View Post
    I NEED HELP GUYS !
    Please help!!
    Did you remember to screw in motherboard standoff in case before putting motherboard in ?
  5. #125
    Dec 2018
    86
    Quote Originally Posted by ninezerofive View Post
    Yeah i did place 6 standoff's that's not the case the issue is with the A.O shield
    alot of people were facing this issue but i didn't get to the solution.
  6. #126
    Dec 2018
    86
    this is where the ao shield should be aligned
  7. #127
    Dec 2018
    86
    THIS IS almost as far as it gets is it fine this way or should it enter the empty space..
    i didn't put the upper screws on the motherboard yetClick image for larger version.
  8. #128
    JimmyH PC Specs
    Processor8700K
    MonitorBenq 27" x 2
    Keyboard Strix
    Mouse ROG Pugio
    Headset Logitech933
    OS Windows 10 Pro
    JimmyH's Avatar
    Nov 2012
    20
    295
    It looks like you haven't got the IO shield all the way in. Most of them need a firm push to pop in right.
    Then I just read that it comes pre-mounted. Have never seen one like it. Can you unmount it and mount the shield into the case??
  9. #129
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,687
    You should test the components work together on the MB box before you put the components in the case! Rushing a build is the surest way to problems.
    When you go to mount in the case...place the standoffs and make sure they are tightened down. Remove necessary GPU covers from case.
    Then gently slide the IO shield into position with the MB at a slight angle...i.e. opposite side to IO shield 3cm higher. The IO shield should gently fit into IO space as you keep an eye on standoffs. At no point should you fit or tighten MB screws. The MB should fit IO panel and lie over standoffs if it fits. If it doesn't send the case back...simple. If you force the MB and tighten screws on a tense board you will break it.
  10. #130
    Dec 2018
    86
    THANKS EVERYONE FOR HELPING ME !!! I LOVE YOU GUYS!
    the setup is complete with no issues POSTING and now im setting up the UEFI for Windows 10 installation, However, I might need some tips and tricks of what to adjust in the bios such as ram frequency it's locked to 2133MHZ is it fine to adjust it from auto to the desirable frequency? and what other AMD RYZEN 2700x settings should i do or i am i set to go ?
ID:	79863Click image for larger version.
Tags for this Thread
