Page 6 of 15 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 143
  1. #51
    ROG Guru: White Belt Array
    Dec 2018
    86
    Quote Originally Posted by Arne Saknussemm View Post
    Cheap PSUs are expensive in the long run
    what do you mean by that ?
  2. #52
    Dec 2018
    86
    has anyone over the internet used my same motherboard in the same case :ASUS ROG Strix X470-F Gaming AMD in Cooler Master MasterCase H500P Mesh White
  3. #53
    ROG Guru: Green Belt Array panzlock PC Specs
    panzlock PC Specs
    Laptop (Model)ASUS X553M, ASUS Zenpad 10 Z300M, ASUS X542BA-DH99
    MotherboardASUS P8Z68-V LX, ASUS Z170-A, ASUS ROG Strix B350-F Gaming
    ProcessorIntel i5-2500K, Intel i7-6700K, AMD Ryzen R7 1700
    Memory (part number)8GB Kingston 1333MhzDDR3 C9, 16GB G.Skill Aegis 3000Mhz DDR4 C16, 16GB G.Skill Trident Z 3200Mhz C16
    Graphics Card #1EVGA GTX 560Ti, ASUS ROG Strix GeForce GTX 1070 O8G OC, Sapphire Nitro+ RX Vega 56
    Monitor32" INSIGNIA 720p, 32" Samsung 1080p C32F391FWN, 32" ASUS 1440p VA32AQ
    Storage #1Seagate 150GB 7200RPM, Samsung 850 EVO 250GB 2.5" 6Gb/s Solid State Drive (X2)
    Storage #2Seagate 500GB 7200RPM, WD Blue 3TB - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
    CPU CoolerDeepcool GAMMAXX 300, Deepcool Lucifer V2, Wraith Spire
    CaseAntec Sonata, Deepcool Dukase V1, Deepcool Dukase V3
    Power SupplyATX 650, EVGA SuperNOVA 850 P2 (X2)
    Keyboard Logitech K220, MSI Interceptor DS4200 (X2)
    Mouse Microsoft 1850, Microsoft 4500, Gamdias Erebos LE, MSI DS 100, Redragon M601 Centrophorus
    Headset/Speakers Logitech Z313, Logitech Z506 (X2)
    OS Windows 10 Home X64, Windows 10 Pro X64 (X2)
    panzlock's Avatar
    Nov 2016
    54
    701
    Quote Originally Posted by SoftAddict View Post
    Cheaper PSU's may have inferior components, lower efficiency, etc... He means, essentially, you'll need to replace it sooner and this is not the component to cheap out on. It distributes power to all your components.
    I would go with EVGA as the warranty is 10 years and their RMA policy is much more forgiving. Also, a little wattage overhead is a good idea for future upgrade requirements. On top of that, PSU efficiency peaks around 40-60% load, although this range might have broadened with newer PSU models.
    Here is what I would recommend:
    https://www.canadacomputers.com/prod...item_id=055089
    https://www.canadacomputers.com/prod...item_id=094072
    https://www.canadacomputers.com/prod...item_id=069557
    https://www.canadacomputers.com/prod...item_id=119359
    Minimum for your specs: https://www.canadacomputers.com/prod...item_id=094071
    https://www.canadacomputers.com/prod...item_id=119358
    I'd like to deploy my troops in her country.
  4. #54
    Dec 2018
    86
    Quote Originally Posted by panzlock View Post
    I found this item i guess i'll go for it : https://uae.souq.com/ae-en/evga-supe...19741/i/#specs
  5. #55
    Dec 2018
    86
    I also found this, i noticed there is mentioned in one of them external source power and the other one internal source power which is weird there should be only external i guess :
    https://uae.souq.com/ae-en/evga-supe...ly-26846334/i/
  6. #56
    panzlock PC Specs
    panzlock's Avatar
    Nov 2016
    54
    701
    These are both god power supplies. They are Super-Flower Leadex platform designs. Again, I'd go with slightly higher wattage if you have the money, but that 750 will be good enough.
    Not sure what they mean by internal/external power source. Now I'm curious, as well.
  7. #57
    Dec 2018
    86
    yeah it should be external ofcourse.
  8. #58
    Dec 2018
    86
    CASE: Cooler Master MasterCase H500P Mesh White Good
    POWER SUPPLY: Corsair VS Series VS650 - 650 Watt Power Supply I think EVGA would be the brand to go with at 750W minimum but this is fine.
    GPU : ASUS GeForce ROG SRIX-GTX 1070TI-A8G Gaming VGA Based on your requirements I'd go with this https://www.newegg.com/Product/Produ...-180-_-Product but the 1070Ti will do just fine.
    HDD: Anything over 1TB from WD.
    SSD:Samsung 970 EVO 1TB M.2-2280 PCIe NVMe Internal SSD(MZ-V7E1T0BW) Good.
    Monitor: ASUS VG278 Monitor Good.
    CPU :AMD Ryzen 7 2700X 8 Core 3.70 GHz Processor with Wraith Pris.. Good.
    RAM: NOT DECIDED SUGGESTIONS Look at G.Skill's Trident Z line. Good combination of performance and aesthetics.
    ASUS ROG Strix X470-F Gaming AMD Good.
    I've settled with this build and ordering as we we speak the only thing that makes its a hassle for me the RAM,PSU and SSD. as you mentioned check the g.skill trident z line, im going for 32 gb can i buy for the a start 16 gb and then upgrade later to 32 just to save some money for the moment. :
    I have this option:
    https://uae.souq.com/ae-en/g-skill-t...-1182200064/u/
    also for the PSU i settled on this and im going to ask them about the details which writtin in as " internal " :
    about the SSD this is the one but im not sure how many slots are there in the x470-f mother board :
    https://uae.souq.com/ae-en/samsung-9...bw-36271436/i/
  9. #59
    Dec 2018
    86
    What Gaming monitor do you recommend as well ? i have one in mind ASUS VG278Q 27 inch Full HD. but if there is another alternative with a good price im up to have a lo0k.
    Note* : I also found this PSU which seems good to me could use some thoughts, i think EVGA is vanished from our country local stores even on SOUQ the warranty does not apply.
    https://gear-up.me/fortron-aurum-92-...m-modular.html
  10. #60
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,682
    Definitely no
    https://rog.asus.com/forum/showthrea...atoes-overview
Tags for this Thread
