Results 71 to 80 of 143
03-29-2019 08:30 PM #71
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
i FOUND out that gear me up is more interesting to buy items, souq is cheaper in most cases but gearmeup.com is detailed. both in UAE
https://gear-up.me/chassis-and-psu/p...lar-135mm.html
03-29-2019 08:54 PM #72
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
will this ram work out of the box on my motherboard
https://uae.souq.com/ae-en/gskill-tr...ry-48422791/i/
https://uae.souq.com/ae-en/asus-rog-...rd-39852067/i/
because i was sure it will im just double checking.
03-29-2019 09:56 PM #73
Arne Saknussemm PC Specs Laptop (Model) Laptop?...No way! (Model?...Jun Amaki...yes way!) Motherboard ROG ZENITH II EXTREME Processor THREADRIPPER 3960X Memory (part number) TXBD48G4000HC18FBK Graphics Card #1 GTX Titan X Graphics Card #2 SLI is dead to me Graphics Card #3 Tri SLI is even dead to Nvidia Graphics Card #4 Quad SLI is dead to everybody especially my credit card Sound Card Xonar Essence STX Monitor ASUS ROG Swift PG279Q Storage #1 Samsung 970/960/950 PRO Storage #2 2x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs CPU Cooler Custom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock Case Nope!...Dimastech Easy XL...let it all hang out man! Power Supply Seasonic 1000 Platinum Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73) Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney! Headset ...firmly on neck Mouse Pad Mouse don't got his own pad man...lives with me Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition Network Router 56k modem Accessory #1 Umm...nice tie? Accessory #2 Err...belt? Accessory #3 3 accessories?! I'm not a girl!!
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
That seems to be a link to some 3600MHz ram...that will not work out of the box....probably would not work even with extensive BIOS tweaking.
3200 would be a top frequency
03-29-2019 10:17 PM #74
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
Through all of this help that i've gained here in this thread i want to thank you all for the fantastic support and help & tips.
I've Checked out many items and they are now on the way to deliver, However, I'm a bit wondering which monitor should i pick im an artist and a gamer so IPS panel type should be the go. Im going to play both RTS and FPS games mostly FPS im looking to prefer Asus as a brand but there is a lot of options i could use some help
03-29-2019 10:25 PM #75
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
OMG !
thank you how didn't i check this out, i was checking out it's benchmark just now on the system it's weird that i've found it and it was averaged as very good.
i already ordered it i'll cancel it.
so for my motherboard which is more suitable 3000 or 3200?
I just went for UserBenchmark and got the top one :
https://gear-up.me/memory/ddr4/corsa...c16-black.html
Green light? P.S it's a 1 slot 1 x 16 is it ideal ? i decided to settle for 16gb at the moment
03-30-2019 06:38 AM #76
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
You want to run dual channel so get a 2x8GB kit
I would personally stay away from Corsair vengeance
The lower the frequency the easier it will be to run in theory...but the quality of a kit is also a factor and the quality of the chips that go into the RAM
The best RAM chips for this platform is made by Samsung...and has timings like 14-14-14-34
A 3200 Samsung B-Die kit will probably run better than some value RAM 3000MHz kit
I would advise you not to save money on RAM or on the PSU. Save money on peripherals and cases etc.
03-30-2019 07:28 AM #77
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
Okay so a 3200 samsung B-Die kit alright i'll search for it, so, you don't recommend g.skill ? :
because this is a good 3200 other than the 3600 you advised me not to buy :
https://uae.souq.com/ae-en/g-skill-t...-1182200064/u/
for some reason i cant find samsung with the same that you mentioned looks like there is no stock, however have a look at this list and tell me if something catches your sight> https://gear-up.me/memory/ddr4.html?...em=1672#page=1
03-30-2019 08:02 AM #78
- Join Date
- Apr 2012
- Reputation
- 505
- Posts
- 13,686
I would recommend G.Skill...but you are best getting a kit they have tested with your chosen MB
They have a RAM configurator https://www.gskill.com/en/configurat...396&model=3407
03-30-2019 08:31 AM #79
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
I'm really frustrated at the moment sellers on Souq for the g.skill are not trustworthy and the details as vague as it gets and the other market which is gearme up they are out of stock.
I found this one here it has all the ram benchmarks for the motherboard :
https://ram.userbenchmark.com/SpeedT...16-8GVKB-2x8GB
this is the customizable search for memory in this website:
https://gear-up.me/memory.html
i just need this favor and help to pick the right ram to work out of the box super great this is the only thing left to decide in this journey.
03-30-2019 08:49 AM #80
- Join Date
- Dec 2018
- Reputation
- 10
- Posts
- 86
which made me worry more is compatibility issues and low performance with gaming.
https://www.youtube.com/watch?v=m6RWEnUsLSY&t=613s
