Results 1 to 4 of 4
    ROG Junior Member Array
    Apr 2016
    4
    Question ASU ROG G571J Turns on and then shuts down - Ideas how to fix?
    It begun happening yesterday after I normally closed the lid.
    I tried cleaning up the fan to make sure it was not a heating issue and nothing changed.
    It does not seems to be an HD issue, however I would love to be wrong because the fix would be cheaper.
    I am not sure what can be done before sending to support.
    Here it is the video of what is happening
    https://www.youtube.com/watch?v=_J1ZJRnN2jM
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    770
    that "please wait" is an OS message.
    you should boot into windows installation disk/usb and try to repair your installed OS.
    you can be guided if you read my guide - that sticky thread at the top of this sub-forum ( or just see my sig for a link )
    also, you should boot winPE or a linux distro to check the SMART value of your HDD...if it is good /dead or going to be soon....
    e.i there's a free old version of partedMagic (Pmagic) - or simply get ubuntu onto a usb.
    Apr 2016
    4
    The problem is the irregularity. There are times where I can enter the recovery menu and then the shutdown happens, there are other times when I even login windows and other times where I can not even begin booting.
    Apr 2016
    4
    The root cause of this issue was the lack of grounding. I walked back what I did before the problem appeared and saw that I made an update in my electrical installation changing the electrical ruler and when I plugged my notebook on it the ground was not connected. After I connected it worked perfectly.
Tags for this Thread
