View Poll Results: What should I do for the upgrade?
Voters
12. You may not vote on this poll
  • 8700k
    2 16.67%
  • 9900k
    7 58.33%
  • Ryzen 3000 series competitor
    1 8.33%
  • Wait till black friday
    2 16.67%
Results 1 to 7 of 7
    ROG Guru: Yellow Belt Array Veovis PC Specs
    Veovis PC Specs
    Laptop (Model)Eluktronics N131WU
    MotherboardMaximus VI Impact
    ProcessorIntel i7 4770K
    Memory (part number)F3-1866C9-8GXM
    Graphics Card #1Asus strix 1080 A8G
    Graphics Card #2Radeon Navi FE edition
    Sound CardCreative SoundBlaster x7
    MonitorMassdrop VAST
    Storage #1Samsung 850 Evo 1tb
    Storage #22 x Seagate Desktop SSHD ST4000DX001 4TB 64MB Cache
    CPU CoolerCooler Master Sideon 120 XL
    CaseGamerstorm Tristellar
    Power SupplySeasonic PRIME titanium 650
    Keyboard Massdrop ALT keyboard
    Mouse Logitech G602 Mouse
    Headset Sennheiser HD58x Julibee
    Mouse Pad Laser megamat
    Headset/Speakers Creative SoundBlaster x7
    OS Windows 10 pro 64bit
    Network RouterNighthawk 8x
    Accessory #1 Samson GO mic
    Accessory #2 Logitech C9000
    Accessory #3 AVEGANT GLYPH
    Veovis's Avatar
    Jan 2016
    26
    130
    8700k or 9900k for Strix Z390i
    Hi guys.
    I'm looking to upgrade my system from my current delidded 4770k. However, I'm using the gamerstorm tristellar case now which means whatever I build will be restricted to the itx form factor and a 120mm aio radiator.
    The reason for this particular motherboard is the DC ram support. I like to use the extra headroom to ram disc games for quicker loading times and use it for cpu rendering. The one issue is clearance as the ram is 80mm and the case is 85.
    The issue that lies ahead is Delidding/longevity.
    My 4770k/Maximus VI impact is showing signs of EoL support, and I used liquid metal to boost the clocks from 3.5 to 4.6 in order to stream youtube at 4k to jump the frame rate issue.
    Anyway the delidding issue: I have a DeBauer 1551 delidding tool. And I know the 8700k isn't soldered so replacing the paste would be relatively painless. The 9900k is soldered so there's a risk of cracking the dye in the replacement process.
    Or should I just wait till black friday after the launch of the Zen 2 and see if there's RYZEN itx boards that will support 64gbs of ram?
    ROG Member Array
    Aug 2018
    13
    19
    The timing of your post LMFAO. I quite literally assembled my new mITX rig earlier today on this exact mobo (Asus ROG Strix Z390-I Gaming) with a new 8700K. The performance gains over the 8700K by the 9th gen processors are quite literally in the 1-4% range. I couldn't justify shelling out the extra cash for a 9th gen cpu.
    My main gaming rig is a first gen Ryzen R7-1800X on an Asus ROG Crosshair VI Hero mobo. As appealing as the next-gen Ryzen CPUs seem to be, mobo support in the mITX form factor is atrocious for AMD. Even Asus' support for AMD mobos in general are terrible. I'll still consider AMD in the future for ATX builds, just no longer Asus for the mobos. But, imo, Intel is the way to go for mITX and the Z390-I mobo from Asus is SWEET. It's basically the best mobo you can get for Intel-based mITX, and AMD is not going to come even close to it in the mITX market.
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,832
    Quote Originally Posted by Veovis View Post
    Hi guys.
    1. If opting for the 9900K I personally wouldn't recommend delidding the CPU, this isn't much of a dilemma as the soldered TIM performance is decent. A reasonable loop should have no issues cooling 1.35v 5GHz and beyond assuming the chip is capable of such.
    2. Ultimately, the decision is your own and comes down to workload. Look for similar performance metrics for your use case and see if there is any benefit to the additional cores. If you tend to stream using the CPU and the price isn't an issue, then it's a worthy investment. Note that NVENC is a capable alternative also without putting too much overhead on the GPU.
    3. Can't comment on unreleased AMD products
    Jul 2016
    182
    It really depends on your use case. If you plan on streaming/editing +game, and the additional cost is not an issue, I would get the 9900k.
    Veovis PC Specs
    Veovis's Avatar
    Jan 2016
    26
    130
    Thanks for the responses. I think I'll follow the advice on getting a 9900k, but I'll wait till black friday for the sale (I think I can get my 4770 to last till then as long as I don't do streaming for now)
    Thanks for your votes and suggestions.
    ROG Member Array
    Apr 2014
    24
    Not that this adds anything but I also have a 4770k, and I just ordered a 9900k yesterday. Pretty damn excited!!
  7. #7
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    80
    948
    Solid plan.
    I also agree with SS above, no need to delidd the 9900k as the improvement is minimal at best. A top end AIO or good water loop will handle it fine.
Tags for this Thread
