PG348Q wont' switch to 100Mhz
elpenajr
My PG348Q all of a sudden will not switch to 100Mhz.
I've made sure to enable OC in the monitor OSD, it was working in the past and has now stoped all together.
I swapped out two 1.4 DP certified cables to ensure it wasn't the cable.
Please help.
6 REPLIES 6
cljustin
Please power cycle your monitor, then try again.
I've tried this several times
1mluer
Level 11
hmmm I have this monitor without any issues. Let me look in the manual to see if there is a saving setting procedure.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
1mluer
Level 11
Make sure you also set the nvidia driver to 100hz as well. Go into nvidia driver and select monitor refresh rate at 100hz not 60hz. If the driver is at 60hz you will never get the 100hz
i9-10900k
ROG Matrix 2080 ti
100Mhz is not on the list of options. I'm getting alot screen tearing in games. I don't think "G-Sync" is working on the monitor either although the LED on the monitor is red for "G-Sync" enabled.
Volt
This might be worth checking. I had some minor issues with not getting it to stick in overclocking mode.For I was using the joystick to select the option to do Overclock at 100hz. But I wasn't hitting the button for it to make that selection.
