Results 1 to 5 of 5
    ROG Guru: Orange Belt Array rjbarker PC Specs
    rjbarker PC Specs
    MotherboardMaximus XI Extreme (BIOS 1503 to 1903)
    Processor9900K @ 5.1 Ghz w EK Velocity
    Memory (part number)32 GB -Dominator Platinum 3200 Mhz CAS 16
    Graphics Card #1Evga RTX 3080Ti FTW3 Ultra w FC EKWB
    Sound CardOnboard Realtek
    MonitorDell Alienware 34" Ultra wide 120Hz Gsync
    Storage #1Samsung 970 Pro 512G M.2 NNMe
    Storage #2Samsung 860 Pro 512G & 256G
    CPU CoolerEK Supremacy Copper w Nickel Plating
    CaseCorsair 900D
    Power SupplyCorsair AX 1600i
    OS W10 HP x64 - 21H1
    Accessory #1 480 * 360 * 240 XSPC Radiators (15 Fans) w 4 Channel 200W Fan Controller
    Accessory #2 XSPC Photon Rez / Vario Pump combo
    Accessory #3 Fesser Flex Tubing - Bits Power Fittings & EK SLi Terminal
    rjbarker's Avatar
    May 2013
    37
    316
    Connecting 5.1 Ch Surround Speakers (Logitech Z906)
    Hey folks...just connected my Z906 Surround System to my MXI E via SPDF Optical Cable (vs the included separate Audio Jack) ...will Digital Audio input still produce 5.1 Ch Surround Sound?
    Cheers
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,563
    Test , Hope This Is Useful I Have Logitech Z5500 Speaker But Use Separate Audio Jacks For 5.1and a Realtek Audio Driver With Speaker Fill,
    https://www2.iis.fraunhofer.de/AAC/multichannel.html
    rjbarker PC Specs
    CaseCorsair 900D
    rjbarker's Avatar
    May 2013
    37
    316
    Quote Originally Posted by toronto699 View Post
    Thanks for that helpful link.....tested with just SPDF Optical and couldnt detect 5.1 Ch ........so unplugged that Optical Digital Cable and went with the cable that came with Z906 System...retested and defintely 5.1 Ch ........
    .....I always thought the Optical SPDF Digital was better? But it doesnt seem so for 5.1Ch .....
    ...What am I missing here ? ....shouldnt connecting the MXI E to my 906 Surround System via Digital SPDF Optical out be better than regular Audio Speaker Jacks ?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    351
    8,112
    Depends on the encoding as there are multiple schemes. The PC has to send an encoding format the Z906 understands. IIRC, there are options in the optical output properties that allow you to enable and disable encoding schemes.
    Also, whether it is better depends on the quality of Logitech's DAC and surround processing vs the onboard DAC and it's surround processing. When sending analog the conversion is done at the source and when sending digital the conversion is done by the destination device. For a high end home theater receiver I would absolutely use a digital connection of some sort. For a desktop speaker system it's debatable as onboard devices are pretty good these days.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Yellow Belt Array Guitarmageddon888 PC Specs
    MotherboardMaximus x code bios1704
    Memory (part number)8700k 5.1/4.9avx
    Graphics Card #1MSI 2080 gaming trio
    MonitorHP Omen 27"
    Storage #1Samsung 970 m.2
    Storage #2Samsung 860 evo
    CPU CoolerH150i
    CaseLian li pc011
    Power SupplyEvga supernova g3 850w
    Keyboard Corsair k70
    OS Windows 10
    Nov 2018
    12
    210
    I have the same speakers and have been down this road. If the encoding on the source is in dolby then it will be in fancy dolby 5.1. Most games nowadays dont encode in that format anymore though. So you just end up with "basic" 5.1 and not true positional audio. Also as mentioned, sending via spdif also means that the DAC on the receiver (i.e. the z906) does the processing. So if you hear the sound quality difference, then that may matter. I have just used the analog outputs and it sounds great so I stuck with that. Have you plugged it in and tested with some dolby encoded files?
