Results 1 to 4 of 4
02-14-2019 09:18 AM #1
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 39
Pop up when plugging in audio cable into motherboard.
I have the Crosshair VII Hero Wi-Fi.
When I plug in a 3.5mm to stereo RCA cable into my speaker out on the motherboard, I see the following pop-up.
I don't want to select headphone, because I'm not plugging in headphones.
But Front Speaker Out seems wrong too, since I'm using the speaker out from the sound card on the motherboard.
It's not the headphone jack on the front part of the computer case.
Does this look right?
It does highlight the green audio port from the rear panel. But again, that pop-up doesn't seem to have the right options, to me.
Thanks.
02-14-2019 09:22 AM #2
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 39
How do I launch SupremeFX on my own (without plugging in the audio cable)?
I can't find it in Windows 10.
Also, it said something about how the impedance was higher than 110 dB.
There was also a drop-down with 3 settings. Extreme, Performance, or Powerful. I think it used to be on Extreme. I set it on Performance now.
EDIT: I figured it out, I click on the RealTek HD Audio Manager.
And the drop-down I mentioned above was for Amplify Level.
I just feel like something's not set up right. But maybe someone else can help confirm.Last edited by nuraman00; 02-14-2019 at 09:25 AM.
02-14-2019 05:05 PM #3
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 318
- Posts
- 7,751
"front speakers" refers to the two main stereo speakers in front of you in a surround sound setup. Those correspond to the green jack on a multi-channel sound card. So it's not referring to the location of the jack on your PC.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
02-16-2019 04:02 AM #4
- Join Date
- Jan 2019
- Reputation
- 10
- Posts
- 39
