Results 1 to 10 of 10
    ROG Member Array
    Jul 2016
    21
    please delete the post-thanks
    please delete-thanks.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,690
    If you are not running liquid through it as part of a cooling loop, leave it empty!
    The port covers are not sealed and you will have pressure leaking fluid out in no time
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    170
    2,214
    1. The OLED screen is far from unchangeable and can be configured by using Live Dash (as per the manual). I use mine to display Water in T, fan speed and CPU voltage.
    2. Any premixed fluid is fine. I use EK Solids (Please only fill the block if plumbed into your loop, otherwise leave dry)
    ROG Member Array
    Jul 2016
    21
    thanks for the answers...
    ROG Member Array
    Jul 2016
    21
    Quote Originally Posted by Silent Scone@ASUS View Post
    1. The OLED screen is far from unchangeable and can be configured by using Live Dash (as per the manual). I use mine to display Water in T, fan speed and CPU voltage.[/B])
    i installed latest version of Ai suite, latest version of LİveDash... whatever i choose on live dash menu, it doesn't reflect to oled screen.it stays at cpu temp. all the time.
    Mar 2016
    170
    2,214
    Quote Originally Posted by theVatansever View Post
    time.
    Will try to rep later. Can you confirm the version number? Personally not had any issues with LiveDash on the Formula XI.
  7. #7
    ROG Guru: Orange Belt Array ThrashZone PC Specs
    ThrashZone PC Specs
    MotherboardASUS z490 maximus XII Apex 2nd x299 Rampage VI Apex
    Processori9-10900k & i9-9940x
    Memory (part number)Trident-Z 3600c16 2nd Trident-Z 3600C16 both Samsung B-Dies
    Graphics Card #1EVGA 1080ti FTW3 water block 2nd Titan Xp copper water block
    MonitorAOC G2460PG 24"G-Sync 144Hz & ASUS VG248QE 24" 144Hz
    Storage #12-Samsung 970 Evo Plus 500gb M.2 & 2.5" ssd's 850 pro's for os 850 evo for games
    Storage #22-LG Blu-Ray WH16NS40
    CPU Cooler2-240GTX with Heatkiller-4-Pro/ vrm water block Both&x299 2-280GTX 2-D5's before and after rads
    Case2- Corsair 450D with second floors for 240GTX & 280GTX rads enclosed and filtered on top
    Power SupplyEVGA 1000P2 2nd EVGA 1200P2
    Keyboard Logitech G910 Orion Spectrum 2nd Logitech G710+
    Mouse 2-Red dragon Perdition
    OS Win-7 & win-10 pro on both systems Win-7 everyday os
    Accessory #1 Optimus Foundation copper plexi 2nd Optimus SigV2
    Accessory #2 ModmyMods clear coolant
    Accessory #3 ModMyMods 3/8-5/8" clear soft tubing/ MORA 360 Pro x2
    ThrashZone's Avatar
    Oct 2017
    23
    390
    I'm sure an image of this water cooling system would be clearer than the description of it
  8. #8
    ROG Enthusiast Array tunc8686 PC Specs
    tunc8686 PC Specs
    MotherboardAsus Rog Maximus X Hero
    Processor8700K @5Ghz
    Memory (part number)Corsair Dominator 32GB (4*8Gb) 3200Mhz
    Graphics Card #1Asus Rog Strix 1080Ti OC
    MonitorAsus VG248QE
    Storage #1Samsung 950Pro 512Gb
    Storage #2Samsung 850Pro 256Gb
    CPU CoolerEKWB Costum Cpu Block
    CaseThermaltake View 71
    Power SupplyEvga Supernova 1000P2
    Keyboard Steelseries 7G
    Mouse Steelseries Rival 700
    Headset Corsair Void Pro
    Mouse Pad Steelseries QMass
    OS Win10
    tunc8686's Avatar
    Sep 2014
    11
    63
    xi formula
  9. #9
    Apr 2012
    505
    13,690
    I no longer need to take strong hallucinogens...I just read select threads on ROG Forum
  10. #10
    ROG Member Array
    Jul 2016
    21
    thanks, the board is returned. Just got gaming-e, what an awesome board..posts quicker than Formula Xi, caps and chokes are dead silent at all loads, comparing to formula xi (formula xi at idle has some strange coilwhine but not at disturbing levels, at %100 load of 9900K@5ghz, it makes you feel with that buzzing noise that it has some strong current on it, however gaming-e has 0 noise...vrm heatsinks are a lot cooler at all testings, just warmer than my body, definetely not hot...and the rog eye on the io shield is much better than what's given on formula xi...) couldn't be happier.
