Results 1 to 3 of 3
    ROG Member Array
    Dec 2018
    5
    ROG Thor 1200w fan off?
    Hi ROG Friends,
    I am wondering about the fan on the Rog Thor 1200w. I have this in my system and today when I started it up I noticed that the fan was not on. I have 7 other fans in my case cooling things down and another 3 smaller fans on the GPU. I am wondering if this thing only turns on as needed? or is my Thor malfunctioning?
    I did a quick google search but didn't see anyone else asking about the fan being off.
    Thanks in advance for insight!
    Best Regards,
    -Steve
    ROG Guru: Orange Belt Array pndiode PC Specs
    pndiode PC Specs
    Laptop (Model)ASUS G752VL-DH71
    MotherboardROG Maximus XII Formula
    ProcessorI7-10700K
    Memory (part number)G-Skill F4-3600C19Q-32GTZRB
    Graphics Card #1ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    Graphics Card #2ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block
    MonitorLG UltraGear 32GN50T-B
    Storage #1WD Black SN750 1TB
    Storage #2WD Blue 4TB (4 ea)
    CPU CoolerEK PE 360 (Top), PE 240 (Front), and Xres 100 Elite
    CaseROG Strix Helios
    Power SupplyThermalTake Toughpower 1200W
    Keyboard ROG Strix Scope RX
    Mouse Logitech MX Master S2
    Headset ROG Strix Fusion 300
    Mouse Pad Generic
    Headset/Speakers Bose Companion 3 Series II
    OS Windows 11 Pro 21H2
    Network RouterGeneric
    Accessory #1 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
    Accessory #2 ASUS External 16X BLU-RAY Writer
    Jan 2016
    31
    277
    What position is the 0 dB Fan button on the back of the power supply set to?
    On = Power supply fan will cut on when it reaches a certain load or temperature (passive mode, apply power to fan when it reaches this load or temperature, but increase fan speed when load or temperature increases and decrease (turn off) accordingly).
    Off = Power supply fan should be on all the time (active mode, forget 0 dB and apply power to fan now, but increase fan speed when load or temperature increases and decrease accordingly).
    I don’t own the power supply, so I could be wrong.
    ROG Member Array
    Dec 2018
    5
    Quote Originally Posted by pndiode View Post
    Thanks so much for educating me! I had no idea about the 0db switch, all would seem well then, I am going to keep it as is because there is plenty of ventilation in the case and airflow is ideal.
    Thank you again!!
Tags for this Thread
