02-16-2019 07:53 AM - last edited on 03-06-2024 08:43 PM by ROGBot
02-19-2019 10:57 AM
02-19-2019 11:10 AM
xeromist wrote:
There is no detection with the optical connection so you just want to make sure the cable is clicked in on both ends. You can also click it into the motherboard and look at the other end where you should see red light coming through.
Once the cable is connected you should go to the Windows audio properties and select the digital output as the default audio device. You can only play sound through one output at a time with Windows 10 so if you were using the 3.5mm jack you would have to change the output.
02-19-2019 11:57 AM
02-19-2019 01:50 PM
xeromist wrote:
I'm not sure how the software interacts with digital connections. Since you are sending raw digital signals and it is being decoded on the other end you may not have as much control. When you are using an analog connection everything is processed on-board so any effects or post processing are easy to do.
***Moved to IX board sub-forum
02-19-2019 03:09 PM
